Old 07-09-2017, 08:36 PM   #1
Bandit63
Bandit63's Avatar
Drives: 2011 Camaro SS
Stabilitrak Problem Solved
After changing out rear diff on my 2011 SS had service stabilitrak, ABS light and TC off light on. Checked codes found C-0050 right rear wheel sensor. Swapped right rear sensor with left rear and still had the same code. Removed right rear wheel bearing hub. Found one of the tabs on the 3 tab washer that goes on axle had broken off and was stuck on the magnetic ring on the hub. Removed it from hub, put back together and problem was fixed. Thought this might help someone with similar problem.
MRR M228 Wheels, Circle D 3200 Stall, 3.91 Gear, Texas Speed VVT 3.2 Cam, CHE Rocker Arm Bushings, Texas Speed Headers, No Cats
Bandit63 is offline   Reply With Quote
Old 07-09-2017, 08:38 PM   #2
Bandit63
Bandit63's Avatar
Here's pic of the washer
Old 07-09-2017, 09:27 PM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Axle shim to keep axles from clicking when turning...
