Old 07-10-2017, 01:34 AM   #1
Earnhardtfan77
Drives: Summit White 2012 1LT/RS
Surging idle on startup
So I have been having this issue for a while now and can not figure out what's going on.. I've tried switching the maf sensor out tried switching the map sensor out and tried switching the throttle body back to the stock one with no change. I uploaded a video so you can see what is going on.any ideas. https://youtu.be/8ge0C1-xzJA
2012 Summit White 1LT/RS
Cold Air Inductions CAI, VMaxx ported throttle body, RX catch can, Led Interior Lights, Led License plate lights, Hood Spears, Blacked Out Rear Trunk panel, Gills, Blacked Out Front Fascia, and Bow tie
Earnhardtfan77 is offline   Reply With Quote
Old 07-10-2017, 01:55 AM   #2
TLewis24
Drives: 2010 Camaro SS
That's odd.. my guess was going to be MAF related but sounds like you tried.. does it always stop after the first few surges?
TLewis24 is offline   Reply With Quote
Old 07-10-2017, 02:07 AM   #3
Earnhardtfan77
Yeah it does it a few times and then settles down.. I've searched for vacuum leaks also but couldn't seem to find any
Old 07-10-2017, 08:55 AM   #4
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Throttle or crank position sensor?
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 07-10-2017, 10:27 AM   #5
Earnhardtfan77
I have not tried the throttle position sensor or the crank sensor
Old 07-10-2017, 04:28 PM   #6
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
Does this happen if you start the engine when it is warm, or just on cold starts?
Jazzzed is offline   Reply With Quote
Old 07-10-2017, 04:31 PM   #7
Earnhardtfan77
It happens on every startup..its a little more dramatic when its on a cold startup
Old 07-10-2017, 04:39 PM   #8
Jazzzed
Jazzzed's Avatar
On one hand, its like it can't decide if it wants the cold engine high idle, or the warm engine low idle. I would consider the engine and intake temp sensors. In my mind, this has to be a sensor issue of some sort because the problem goes away. A vacuum leak or a mechanical issue would occur consistently I would think
By the way, you did address the throttle position sensor when you swapped throttle bodies.
Old 07-10-2017, 04:43 PM   #9
TheFlyingBananaSS
Jazz may be on to something here. It sounds logical.
Old 07-10-2017, 04:57 PM   #10
Jazzzed
Jazzzed's Avatar
Since the O2 sensors should be in open loop during startups, you can probably scratch them off the list.
I have seen other people up here who have had this problem on the V6, but it was often right after installing the 80mm throttle body. The fix seemed to always be something with the tune in those cases. So again, something throwing the computer off.
Have you disconnected your battery to reset the computer? I might try that just for kicks.
Old 07-10-2017, 07:48 PM   #11
Earnhardtfan77
yeah i was thinking the same thing, and its also not throwing a CEL so no help there lol..my brother has the same car as i do so im playing pick a part with his car lol...ill try the engine and intake temp sensors next and see what that does..do you think if it was the crank sensor it would throw a CEL
yeah i started the car and caused a vacuum leak and you can def. tell when there is a vacuum leak
Old 07-10-2017, 07:50 PM   #12
Earnhardtfan77
i was thinking about doing that as well, ill give that a try today also ( disconnecting the battery )
when i swapped my ported one back to the OEM one wouldnt it have corrected itself if it was the throttle body?
Old 07-15-2017, 02:31 AM   #13
Earnhardtfan77
Thanks to jazzed I may have found my culprit. When I unplug the engine coolant temperature sensor the car starts normally. No surging. The fans come on and thinking the car is overheated but no surging. When I plugged it back in the surging returned.
When I replace the sensor should I get the OEM parts or just go to orielys or AutoZone and use what they have... Also is all my coolant going to dump out if I remove the sensor without draining the coolant first
Old 07-15-2017, 04:31 AM   #14
Jazzzed
Jazzzed's Avatar
Nice. If it was me, the price would probably help me decide on whether to go OEM or aftermarket. I can't imagine there is much difference in the design/engineering between the two. As for whether or not the coolant makes contact with the sensor or if it is just mounted into the block, I don't know. If it does come into direct contact with the coolant though, then make sure you put some teflon tape on the threads to make sure it seals.
