Old 07-10-2017, 11:34 AM   #1
loves_bruins
Drives: 2010 Camaro SS2
EVAP I/M service incomplete with JRC tune
Hello,
I'm really hoping someone with a brain can help me. My chevy mechanic certainly can't.
I have a 2010 Camaro, L99 with a recent tune from JRC. The EVAP Monitor test is still reading incomplete. It is the only one.
I've done the stupid GM drive cycle test 5 times. Does the JRC tune tune out that test? I would think not.
Please help. This stupid thing has to pass inspection as it has a clear sticker that has run out.
Thanks
/Loren
loves_bruins is offline   Reply With Quote
Old 07-10-2017, 11:39 AM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
I would contact JRC directly for this
SSEssence is offline   Reply With Quote
Old 07-10-2017, 11:44 AM   #3
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
You should be able to pass with one system not ready.
It was the evap system on my Camaro that read not ready when I passed a few months ago.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 07-10-2017, 11:48 AM   #4
loves_bruins
@CamaroFred: I reside in "Live Free or Die" state, where ALL I/M tests have to complete if they are available.
Old 07-10-2017, 12:13 PM   #5
loves_bruins
I just talked with Ted over at JRC. The tunes do not touch EVAP system or testing.
Old 07-10-2017, 01:53 PM   #6
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
Can't you force the evap monitor test while in mode $6 diagnostics.
Coleroad is offline   Reply With Quote
Old 07-10-2017, 02:16 PM   #7
loves_bruins
@Coleroad How?
Old 07-10-2017, 02:23 PM   #8
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
With the proper scan tool. Your dealer should have been able to do it for you. That's how a real technician tests his work after fixing the evap system. Not tell you to go drive it a few days and bring it back if the cel light comes back on.
Old 07-10-2017, 02:26 PM   #9
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Did you disconnect your battery lately? This will cause the readiness info to clear. Doing the drive cycles will pass most readiness but sometimes it takes hundreds of miles for EVAP to pass. Had this happen when putting a new battery in my Avalanche 2 days before getting it inspected. After drives cycles it passed all but EVAP. But in NY we only need to pass 3/4
Old 07-10-2017, 02:34 PM   #10
loves_bruins
@Coleroad, This is why I prefaced my initial request with "someone with a brain" My chevy dealership(service) had no clue what mode 6 diagnostics is. Is there a "cheap" scan tool that supports mode 6 diagnostics?
Someone recommended one that was 1100 bucks. Kinda steap.
Thanks!
/Loren
Old 07-10-2017, 02:52 PM   #11
Coleroad
Coleroad's Avatar
Drives: 13 Camaro
I would recommend the ds150. Not sure what the cost is , but is a full functioning bi directional scanner.. Delphiautoparts on YouTube has a great diagnostic series. These videos are like an hour long each, and for many different vehicle systems.
Old 07-10-2017, 03:10 PM   #12
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
The EVAP readiness definitely takes the longest to complete. During the GM drive cycle, did you do the idle for 3 minutes after a cold start with the air conditioner, rear defroster and all other electrical accessories on? How about the 3 minutes of driving at exactly 55mph? Mine completed very easily after just those two.
Jazzzed is offline   Reply With Quote
Old 07-10-2017, 05:38 PM   #13
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
In the EVAP test multiple cold starts will be required. You can't just drive around, turn the car off and start it up again. It has to see engine temp and ambient temp nearly the same to be a cold start.
JerTM is offline   Reply With Quote
Old 07-05-2020, 12:35 PM   #14
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
Old thread, but I have this issue. Not a emissions issue for me. I recently did an LSA blower on my LS3 and I have a new EVAP solenoid. I run HP Tuner and I have tune shop I work with locally. All is well and runs fine. Except when I check engine codes I get EVAP incomplete. No idea what the deal is or if I should be worried.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
evap, tune
