Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 07-11-2017, 03:18 AM   #1
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
complete 4l80e swap kit
I've decided to make the swap to a powerglide. that is the only reason for selling. trans was just rebuilt and the converter was cut/cleaned(have paperwork for this) and the cooler was flushed.
I have....
jakes performance stage 3 autoshift 4l80e
pcs 2000 trans controller/harness
circle d 258mm triple disc converter
tci deep cast aluminum pan
Lokar 36" flexible dipstick
crossmember with driveshaft loop built modified for trans mount
trans cooler(biggest one b&m makes) with an lines/fittings(all fragola)
b&m quicksilver shifter modified to fit the factory console and m6 boot
flexplate with spacer
trans inspection cover
dss 3.5" aluminum driveshaft with strange billet yoke
prefer local pickup but will ship at your expense.
5500 obo for everything. located in findlay ohio
ttshovel is offline   Reply With Quote
Old 07-11-2017, 11:13 PM   #2
Luvdamud
Drives: 2010 SS
Just sent you a pm. Please give me a call at the number in the pm
Luvdamud is offline   Reply With Quote
Old 07-12-2017, 07:19 AM   #3
ttshovel
ttshovel's Avatar
SOLD
