Old 10-31-2009, 11:28 PM   #1
Verio
Taking it 1 day at a time
Verio's Avatar
Drives: 2010 Chevy Camaro 2SS/RS Auto
Send a message via MSN to Verio
Distance on Remote Start?
Just curious what the distance is normally for others? I think my fob may be defective... often times I have to hit the Lock > Remote Start button combo 3-4 times before it starts, and that's much closer than what it takes to make the horn honk when I press the lock button.
Order#: NJWGTF
1100, Preliminary order accepted 04/27/2009
6000, Delivered to the customer 07/23/2009 - 3 Months (worth the wait!!)
Verio is offline   Reply With Quote
Old 10-31-2009, 11:34 PM   #2
Beandip2811
#25263
Beandip2811's Avatar
Drives: 2010 Camaro
Should be with in two hundred feet. If you need to be closer than that it may help to have your remotes reprogramed. And I'm sure you know this but just make sure that you press the lock button first, then the remote start button for 2-3 seconds. If you can see your car the lights will flash on the lock cycle then flash twice just before the car starts. When your car does start it will leave the running lights on. Hope that helps.
Beandip2811 is offline   Reply With Quote
Old 11-01-2009, 08:24 AM   #3
DrumDawg
DrumDawg's Avatar
Drives: BumbleBee, 67 Firebird,79 Porsche
80-100 yards
Ordered 9July09-2SS,RS,Transformer
1100 = Preliminary Order:7/13/09-NMGCZB
3000 = Accepted By Production Control-09/14/2009
3400 = Broadcast:09/14/2009
3800 = Produced:09/17/2009 2G1FK1EJ5A9147250
4000 = Available to ship 28Sept
4200 = Shipped-Rail-Detroit at 3AM on 5Oct, Departed for Miami, Ohio @ 3AM, arrived in Cincinnati, Ohio, 7 Oct 0749 arrived in Louisville Kentucky,at Kane Ave Tenn.@ 8:30PM,left for Wauhatchie, Tennesee 10Oct,Waycross GA10Oct,Jacksonville FL 11 Oct.
5000 = Delivered to the dealer 14Oct09
6000 = Delivered to the customer 17Oct09
DrumDawg is offline   Reply With Quote
Old 12-17-2009, 08:18 AM   #4
shankomatic
shankomatic's Avatar
Drives: 2010 2LT V6 ABM
I have also noticed the remote start range is much lower than the range of the door lock/unlock. The lock/unlock seems to work from well across a large parking lot, and the remote start feature seems to only work within 50 feet or so.
shankomatic is offline   Reply With Quote
Old 12-17-2009, 08:34 AM   #5
AWK
Drives: Inferno Orange Camaro RS
Hold the fob vertical, don't point it at the car. This will increase your range
AWK
AWK is offline   Reply With Quote
Old 12-17-2009, 08:53 AM   #6
Mzodarg
Remembering those in Blue
Drives: 2010 Camaro 2SS Blk w/IOM Int
Mine works from a third story window about 250 ft away, and as long as it cold enough-my heated seat will work also.
Mike
Mzodarg is offline   Reply With Quote
Old 12-17-2009, 09:33 AM   #7
Verio
Verio's Avatar
Exactly. I can unlock/lock the car from across the parking lot... but I can smash that remote start button 50 times, and nothing happen until I'm almost right in front of it.
Order#: NJWGTF
Old 12-17-2009, 09:46 AM   #8
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: was 2010 2LT RS 2G1FC1EV4A9103434
AWK
+1 - I found once I held it vertical I was able to Lock / Remote Start from across the parking lot consistently.
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 - Traded-in 8/31/2019:
tjd24 is offline   Reply With Quote
Rough Engine Start After Tune? Tanner Tuning / Diagnostics -- engine and transmission 9 10-08-2009 01:25 PM
Remote Start Durability kanys 5th Gen Camaro SS LS LT General Discussions 33 03-28-2009 08:43 AM
Official Camaro Options & Standard Equipment for all Trim Levels headpunter Camaro Price | Ordering | Tracking | Dealers Discussions 300 02-18-2009 01:23 AM
First engine bay shots of the 2009 Chevy Camaro + other exterior/interior bits DetroitWonk Camaro Photos | Spyshots | Video | Media Gallery 212 05-08-2008 03:10 PM
