Old 07-13-2017, 11:32 AM   #1
Cornflakes'Camaro
Counting down the days...
Cornflakes'Camaro's Avatar
Drives: Black 2011 2SS/RS
Replace toe rod and Trailing arm bolts?
Im replacing my trailing arms and toe rods. I know these are torque to yield bolts, so I called the dealership who said it would be $58 per side for the bolts. Does anyone know of a better price or place to buy these bolts?
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
Cornflakes'Camaro is offline   Reply With Quote
Old 07-13-2017, 12:38 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Technically you should replace TTY bolts, however, when it comes to these suspension bolts just use some blue loc-tite and tighten until you grunt once or twice and they'll be safely fastened. I did a bunch of suspension work a few months back including said arms and followed the above method with no issues of loosening, noises, discomfort, etc.
KillboyPowerhead is offline   Reply With Quote
Old 07-13-2017, 01:21 PM   #3
Cornflakes'Camaro
Awesome! Also, I removed the knuckles for another project install. Can I get some simple grade 8 bolts for that?
