Old 07-15-2017, 07:55 PM   #1
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Getting Ready for Laguna Seca... E85
Would have cost me 400$ in fuel at the track for 100oct
Instead was 90$ and makes more power with all the other benefits!
Crash76 is offline   Reply With Quote
Old 07-15-2017, 08:38 PM   #2
himmy33
Go Cougs!
himmy33's Avatar
Drives: 2012 Ashen Gray ZL1
Damn that's a lot of fuel. Have fun at the track!
himmy33 is offline   Reply With Quote
Old 07-15-2017, 08:39 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
My hero! Just did E85 conversion for that reason. I race @ NCM when I get the chance. They have a pump nearby with E85. But I like the idea of taking E85 to the track...
-Don
747 RWHP 794 RWTQ
Old 07-15-2017, 11:21 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Nice.
What mods do you have? RWHP?
I'n thinking this is the next move for me as well....
Mods:
Old 07-15-2017, 11:53 PM   #5
Crash76
Team 913
Dont know what my rwhp is ...
JRE Smooth Idle, ARH LTs, 23% pulley, Rotofab, VMax Ported TB.
DSX Tuning/Flex fuel Kit/Aux Pump
ID 1050x
Lots of suspension mods and cooling mods as well
Last things on my list to do will be a new cam, ported heads (possibly gmmc ls9), and ported blower over the winter.
Old 07-16-2017, 12:06 AM   #6
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 07-16-2017, 12:50 AM   #7
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
You want to go with a bigger cam I'm assuming?
Can'tHave2MuchHP is offline   Reply With Quote
Old 07-16-2017, 03:18 AM   #8
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
That's because with E85 you will get around 1/2 the MPG as gasoline would provide.
When Indy Cars changed from gasoline to ethanol the required minimum MPG went from 4.5 to 2.1.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 07-16-2017, 04:50 PM   #9
Crash76
Team 913
Yeah, probably a BTR Stg 3 Cam...
IMSA WeatherTech runs E15 i believe
This studf comes in at 80% Ethanol in the computer...
I actually plan on hauling full can and 15-5gal containers to Laguna, probably wont need it all, bring it back home...
Old 07-17-2017, 11:10 AM   #10
E. Bryant
Gearhead
E. Bryant's Avatar
Drives: 2012 ZL1
I don't have a good way to haul fuel to the track (I drive my car there), or else I'd try the same thing. As it is right now, I can't make it through three 30-minute sessions without starving the fuel pickup, so getting through only two sessions would be tough on E85.
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip.
11.193@128.13 in 515' DA
E. Bryant is offline   Reply With Quote
Old 07-17-2017, 02:32 PM   #11
GONMAD510
Drives: 2013 ZL1 M6
I want to go E85 but I don't have enough places around me that sell it. I daily drive my car and my mileage is already in the single digits. I would be at the gas station constantly.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 07-17-2017, 06:17 PM   #12
Dixon Racing
Dixon Racing's Avatar
Drives: 2015 Z28 Red Hot
Crash76, where in Cali are you? I'm in the 831 near Laguna Seca, and don't think I've ever seen E85 around here. I would like to switch but would hate to drive to the bay to fill up gas canisters for each track day.
Also, I'm going to Thunderhill this Friday with HOD, were you planning on going to that as well?
Dixon Racing is offline   Reply With Quote
Old 07-17-2017, 07:15 PM   #13
Crash76
Team 913
Im in Stockton area, i travel up to Elk Grove for my E85 ... propel stations always have 70% or greater ethanol, so far every fillup has been 80%
Ive been to thunderhill a few times , but no i wont be there this friday due to work, HOD is awesome to run with...
Nice thing about flex fuel sensor is you can run 91 to full e85
