Old 07-19-2017, 05:08 AM   #1
Inspiro
Drives: 2012 Camaro SS
Valve spring compressor recommendations
Hi All
Which valve spring compressor do you recommend for Gen 4 & Gen 5 LS engines(mostly L99, LT1 & LT4), for engine in-vehicle cam replacament jobs
The price range is sooo big
Thanks in advance
Inspiro is offline   Reply With Quote
Old 07-20-2017, 02:58 PM   #2
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Well gen 4 engines have several different head types. I used a crane cams tool for LS3 heads.
Bildo is offline   Reply With Quote
Old 07-20-2017, 07:47 PM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
this...http://www.ebay.com/itm/Proform-6760...-/232240266870
Old 07-20-2017, 09:41 PM   #4
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Trick Flow
https://www.summitracing.com/parts/tfs-90307
zz430camaro is offline   Reply With Quote
Old 07-21-2017, 01:07 PM   #5
Inspiro
mostly L99, LT1 & LT4, I edited the main post
Old 07-21-2017, 05:07 PM   #6
krusher
krusher's Avatar
Drives: 2010 Camaro SS/RS CGM
I went with comp cams spring comressor. Not for sure why but on one side it was awesome. The other side it sucked. The bolts that screw into the head seemed too short and i bent them compressing the drivers side. Hence why they pack two sets of bolts. Since they bent they screwed the threads on a few of the holes. If they were longer and had more thread engagment it would have worked better
krusher is offline   Reply With Quote
Old 07-21-2017, 05:08 PM   #7
krusher
krusher's Avatar
Also should have been a grade 8 bolt. They seemed cheap
Old 07-22-2017, 03:17 AM   #8
TLewis24
The crane cam one was extremely useful, worked perfectly with minimal space usage so I could do it without pulling the heads.
TLewis24 is offline   Reply With Quote
