![]() Drives: Grey LS Join Date: Feb 2013
Aural warning,Radio,AC fail
Hi, my 13 Camaro recently started to have the radio go out as well as the AC was going on and off. The aural Unit was off so no seat belts, signal, low fuel chimes either. As soon as I pulled the "Radio" circuit breaker, the AC worked fine. The radio obviously doesn't work as well as no aural warnings either, and if I put in that cb everything goes haywire again. The radio could be the problem but I find that those times that the radio works for a few minutes, it works perfectly. So I'm thinking maybe it has to do with a control module that controls the aural unit. Is there a circuit breaker that I can pull that controls there aural chimes so I can tell if it's really the radio that's the issue?
