07-21-2017, 03:36 AM | #1 |
Drives: 2013 ZL1 VR convertible M6 Join Date: Apr 2017
Newbie questions..just bought a '13 ZL1
Just bought a victory red '13 ZL1 manual transmission convertible with 26500 miles from original owner. No mods, all stock except for hurst super shifter, black out kit, invisible bra and built in Passport Laser.
Some newbie questions... 1. Is it wise to replace snout and isolator coupler (with a solid one)? There is no current evidence of malfunction. 2. What grade type of gasoline runs best in a stock example? For example grade 93? Ethanol or non-ethanol? 3. How difficult/expensive is it to acquire a written build sheet for my car? 4. Is synthetic oil best for these engines? What brand is the best? (Prior owner used synthetic). Thanks Rick |
07-21-2017, 06:15 AM | #2 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
1. The isolator may have already been addressed. If it rattles it is covered under warranty, and I would address it at that time.
2. 93 octane only. 4. Synthetic oil only. Most prefer Mobil 1. |
07-21-2017, 09:45 AM | #3 |
W8NN4U
1. you should be able to take the car to your local GM dealer and ask for a service history, at the very least the should able to tell you if the isolator has already been done.
2. you can run less than 93 octane, we don't even have 93 premium here, just 91. If you use crappy fuel, your car will run, well, crappy. The ECM will pull timing to match the fuel, robbing you of power. It will probably hurt fuel mileage (if you care about that sort of thing) as well 4. what JB said |
07-21-2017, 09:46 AM | #4 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
The car runs fine on 91, it is the only thing available in many states. 93 is better but 91 is fine.
Sent from my SM-G955U using Tapatalk
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
07-21-2017, 09:49 AM | #5 |
W8NN4U
Oh, and welcome to the site
07-21-2017, 10:41 AM | #6 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
07-21-2017, 12:05 PM | #7 |
Ok..as requested here are some pictures. Thanks for answers to my questions.
07-21-2017, 02:18 PM | #8 |
W8NN4U
Nice, I had VR coupe before this one. Great color for these cars...
07-21-2017, 03:57 PM | #9 |
ZL1 Pilot
Post or PM me your vin. I can tell you the dealer service history. wether or not the blower has been replaced
07-22-2017, 12:31 AM | #10 |
"BEASTM*DE"
Welcome aboard... Very nice looking car...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
07-22-2017, 07:20 AM | #11 |
Have another question.
The seam at the top of both mufflers look like they have failed. See pics attached. I would like to replace with the same GM muffler. Has anyone had theirs replaced and did you have a Chevrolet dealership order the mufflers and install? |
07-22-2017, 08:10 AM | #12 |
Drives: 2013 ZL1 A6 #4801 Join Date: Mar 2016
Not for sure, but that may be an intentional weep hole for the mufflers. I would not replace unless you can hear a leak. I'm sure others who know will chime in.
07-22-2017, 08:13 AM | #13 |
If you must replace the mufflers I would consider aftermarket over oem. Oem is not that bad, but you can get some free hp if you must replace.
07-22-2017, 09:00 AM | #14 | |
I am going to leave it alone. |
