Old 07-21-2017, 01:13 PM   #1
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
AC condenser hose......
Hi.
I am trying to put my car back together and am lost. Where does the rubber hose, coming from the drivers side AC condenser go to (at the bottom)???
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 07-21-2017, 01:22 PM   #2
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
if it is small diameter hose with no fitting at the end, that is most likely your condensor drain. just hangs down to drain excess moisture.
DvKillar is offline   Reply With Quote
Old 07-21-2017, 01:54 PM   #3
G701LE
G701LE's Avatar
No fitting. There is one going in to the passenger side radiator, then one coming from the driver side! I need to know where the one on the drivers side goes.....
Old 07-21-2017, 03:58 PM   #4
G701LE
G701LE's Avatar
You guys ever get the feeling that someone that has read your post knows, but just don't give a shit!?!?
Old 07-21-2017, 05:30 PM   #5
Spurshot
Drives: 2014 2SS blue
Easy bud. You're asking someone to crawl under their car and frankly, I couldn't get under it.
I can tell you my 2014 has a 1/2" dia hardline with a U bend coming off the driver side top of the condenser. The hardline part has a port on top of the U covered by a cap. This is the "High side port". Right under that on that hardline is a pressure switch. This line goes from the compressor to the condenser. It goes under the crank pulley.
About halfway down on the driver side of the condenser is another line. This line transitions to a small diameter, maybe 1/4". It goes to the firewall where it ties to the evaporator.
There are two other lines that transition to hoses, near the center of the bottom of the condenser. These are the trans cooler lines and they go under the engine on the passenger side. \
Possibly going to a online parts seller's site will show a blow up view.
Spurshot is offline   Reply With Quote
Old 07-21-2017, 05:48 PM   #6
G701LE
G701LE's Avatar
Thanks Spurshot.
I only have 4 outlets/inlets on my condenser. I have the 2 "U shaped" hard lines hooked up on the drivers side. Under those hard lines there is 1 rubber hose hanging. On the passenger side there is a rubber hose coming in from trans?! to the condenser.... I need the one on the driver side, at the very bottom of the condenser (rubber hose)
Old 07-21-2017, 05:59 PM   #7
Spurshot
The two at the bottom are the trans cooler section of the condenser. GM puts the trans cooler as part of the condenser on these cars and also my 2014 truck. You can tell its a trans cooler line by the type of connection to the condenser. The trans cooler lines are push in, with an O ring in the cooler, then a small wire clip slides into some holes and finally a plastic collar slides down the line over the wire clip to retain it.
Old 07-21-2017, 06:01 PM   #8
Spurshot
The AC Freon lines are flanged.
Old 07-21-2017, 06:10 PM   #9
Spurshot
I checked the parts sites. Your condenser is different than mine, because you have hydraulic power steering and that cooler is apparently also part of the condenser. You will have to find someone with a 2010 to help.
Old 07-21-2017, 07:06 PM   #10
G701LE
G701LE's Avatar
Thanks spurshot. Yeah, I have the 2 hard cooler lines with clips running to the front of the radiator. Then, I have 2 rubbers hoses going to the outside, bottom of the condenser.
Old 07-21-2017, 08:02 PM   #11
Spurshot
Those rubber hoses are probably power steering cooler hoses.
Old 07-21-2017, 08:08 PM   #12
G701LE
G701LE's Avatar
Here it is coming out of the side/bottom of condenser. The top hose is running to my trans cooler...
Old 07-22-2017, 11:57 AM   #13
G701LE
G701LE's Avatar
Nobody wants to play guess that hose?!?
Old 07-22-2017, 03:42 PM   #14
Reddog1982
Drives: 2012 L99 2SS
It's not the hose that runs to the bottom of the power steering fluid box? That's all I can see on mine.
Reddog1982 is offline   Reply With Quote
