![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
125k mile engine health check
Rolled 125k miles while I was at CamaroFest7.
Decided to do a quick compression test this morning when I got home from work in it so it was warm. Highest cylinder was 193 psi Lowest cylinder was 170 psi Not too bad especially since it was supercharged for 70k miles of its life. Mobil oil all its life every 5k miles.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Great post! Just goes to show it's not all gloom and doom for well worn LS3's.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
#3 | |
![]() ![]() ![]() ![]() Drives: 2015 1LE Join Date: Oct 2015
Heads and cam LS3
Th400 4.10s
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ‘13 1LE Join Date: Jul 2013
1. What viscosity range you using?
2. Same oil viscosity entire life including with SC? |
#6 |
Yes. 5W30
