07-25-2017, 08:15 PM | #1 |
Drives: 2010 SSRS Join Date: Apr 2015
Motor mounts
So I have a stg3 cam. The engine shakes a lot and I'm getting worried that my mount is detiorating fast or will break. I'm thinking of putting in solid mounts, or close to solid as I can. Will my car end up shaking more with the motor being solid to the chassis?
I don't daily it, it's becoming more of a weekend racer more and more as the years progress so noise and idle vibrations aren't in my concern list. What would all change with the harder mounts in terms of drivability? Do any companies make solid mounts now? I know pfadt And prothane both have close to solid. Hit me with your advice HC
As I lay rubber down the street I pray for traction k can keep, but if I spin and begin to slide please dear god, protect my ride[/I]
10' ls3 2SS/RS, gfx pkg, stainless headers, 3" stainless exhaust, rotofab cai, custom stage 3 cam, 4:11 gears, wall tuned |
07-25-2017, 09:30 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
Your car will shake more with solid mounts as there will be a more solid connection between the engine and frame. You'll get used to it and not notice it after a while. It didn't take me long to get used to my Pfadt mounts.
BMR, Pfadt, Detroit Speed and Prothane offer solid mounts. I don't know if Pfadt still does. My work computer won't let me go to their site. |
07-25-2017, 10:26 PM | #3 |
I'm ok with whole car shaking (looks badass) which is kinda what I expected.
After a little more research it looks like bmr has a bushing swap From the poly to aluminum for a real solid mount. That's the only that I have seen. I have also read that when stiffening up the motor mounts, its recommended to do the same with the trans mount. Looking for that now with minimal luck so far
07-25-2017, 10:40 PM | #4 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Prothane engine mounts..works of art....for manual trans somebody makes a poly insert that apparently works but since I put in the Prothane, everything works perfect..including the 7k shifts!
07-25-2017, 11:02 PM | #5 |
Ive been using my stock M6 trans mount with no issues. This is the third engine it's been behind with all of them making over 1kwhp. If/when it dies, I'll put on a prothane.
07-26-2017, 11:39 AM | #6 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
I have the BMR Polyurethane motor mounts in my car. The car actually shakes less. You feel more of the engine harmonics but not in a bad way in my opinion. Installation was fairly easy.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
07-26-2017, 05:40 PM | #7 |
old school chevy rodder
You have mounts...Plural, and get used to it from a old motorhead its part of the appeal of being cammed, and just as prevalent on any other cammed good car your engine mounts actually have fluid in them in the Camaro and are pretty sturdy.
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, full BMR susp, Speed eng. valve covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, JBA shorties, Lingenfelter check, 1le wheels, spoiler and diveplanes, PCV, Big3racing ice tank, [SIGPIC]etc....
