Old 07-30-2017, 06:16 PM   #1
SS6310
Sandmanzl1
SS6310's Avatar
Drives: 2015 Red ZL1
AFCO heat exchanger issue
Hey guys, this has probably been discussed before but I need help. I have just finished installing my afco heat exchanger with dual fans on my 2015 ZL1 and first let me say the instructions are crap! Anyway, I got it all installed and cranked up my engine to check everything and the fans did not take long to turn on, engine was not even close to being warmed up, and then they were blowing out and not sucking air in. I could not call customer service as it is Sunday. Any help with this issue would be great.
SS6310 is offline   Reply With Quote
Old 07-30-2017, 06:22 PM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Pics would be helpful. Are you certain it's correctly mounted?
JB'sZL1 is offline   Reply With Quote
Old 07-30-2017, 06:26 PM   #3
SS6310
Sandmanzl1
SS6310's Avatar
Yep, just like the instructions say, I can take some pics but it is just like the instructions say. The only thing is it says to hook the orange wire to the white wire on the pump, there is no white wire, two tan and one black.
Old 07-30-2017, 06:33 PM   #4
SS6310
Sandmanzl1
SS6310's Avatar
I just went out and looked at everything and it is just like the instructions say, the black and white wire are mounted correctly, the fuses are mounted correctly, the red wires are on the power of the fuse box. The only thing is the wire on the pump. Says to connect to the white wire and as I said, there were two tan wires and one black. I chose one of the tan wires. I cannot thinks of anything that is wrong.
Old 07-30-2017, 06:43 PM   #5
SS6310
Sandmanzl1
SS6310's Avatar
Bump
Old 07-30-2017, 08:54 PM   #6
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
The instructions are crap!
I remember there was an issue with AFCO fans a while ago where one or both of the fans ran backwards.
I hate to tell you this but you are going to have to call those guys and complain about it.
I believe they will send you a new harness to correct the issue.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 07-30-2017, 09:08 PM   #7
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I'm not an electronics guy, but isn't that a polarity issue? I had a rear electric window in my Avalanche that would roll down if the switch was pushed down. Had to reve see the wiring.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 07-30-2017, 09:09 PM   #8
SS6310
Sandmanzl1
SS6310's Avatar
Yes, the instructions are crap, pisses me off, took much longer than it should have. Thanks for the input though. Sucks, car sitting in pieces.
Old 08-02-2017, 08:29 AM   #9
ADM PERFORMANCE
Drives: Anything I want
Very easy to fix.
If the fans are on the backside (fans against the condenser) than all you do is swap the connectors pins that go to the fans(your reversing the polarity to a make them turn the other direction)
If you put the fans on the front than you need to flip the heat excnager around so the fans are on the back.
That was easy
ADM PERFORMANCE is offline   Reply With Quote
Old 01-09-2020, 10:28 AM   #10
CasperZL1
Drives: 2013 White ZL1 Vert
anyone?
I know this is super old but does anyone have wiring instructions for the Afco dual fan? I recieved the instructions on how to install but nothing on the wiring side....nothing...
2013 zl1 6M
CasperZL1 is offline   Reply With Quote
Old 01-10-2020, 08:16 AM   #11
JB'sZL1
Just install a manual switch on the dash or console. In that manner you can turn it off/on as needed.
Old 01-27-2020, 01:23 AM   #12
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
2013 zl1 6M
I'll check, I'm sure I kept all the paperwork on mine.
FasNuf is offline   Reply With Quote
Old 02-18-2020, 04:08 PM   #13
LagunaSecaZL1
LagunaSecaZL1's Avatar
Drives: 2013 ZL1 M6
Just make sure you bleed the intercooler.
https://www.camaro5.com/forums/showthread.php?t=463858
Corvette Z06/Z07/M7 (2016) Late Model Racecraft Intercooler reservoir and 160* Thermostat.
Sold- 2013 Camaro ZL1 M6 (Black on Black), Detroit Speed Sway bars, DOT 4 Brake Fluid, separate clutch master reservoir, Moroso Catch Can. 2.11 at Thunderhill 100* ambient. Ron Davis Radiator and AFCO Heat Exchanger installed after track day, Roto-Fab CAI.
Sold- 2001 Mustang Cobra -Griggs GR40,M5, Torsen T2-R, 4.10, 14" Brembo fronts, high 1:40s at Laguna Seca
LagunaSecaZL1 is offline   Reply With Quote
