Old 07-30-2017, 10:05 PM   #1
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
Removing compound/wax build up in crevices
Well didn't tape off the jambs and crevices when polishing and then sealing, waxing. Didn't think I'd shoot around in these spots if I was "careful"
Well now I need a trick or tool to remove this white build up from around my car - moldings and crevices on side skirts etc without damaging my paint.
Any tips or tricks or tools I can grab that address this? Took care out in sun today and was surprised how much it stood out everywhere around my car (paint looks amazing tho)!
TIA
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 07-30-2017, 10:06 PM   #2
HDRDTD
Fingernail brush used gently.
Old 07-31-2017, 09:35 AM   #3
KenKat
KenKat's Avatar
Drives: 2014 2LT RS Summit White
Soft bristle tooth brush
KenKat is offline   Reply With Quote
Old 08-01-2017, 09:54 AM   #4
flyinlow89
Smoke Alotapotomous
flyinlow89's Avatar
Drives: 2010 Camaro SS
if you dont have a good brush lying around as suggested, a toothpick will do the trick. if you have it on black mouldings you can try using detail spray or a good (safe) APC and cloth
2010 Camaro TT SS. AGP twin Turbo
http://i377.photobucket.com/albums/oo216/flyinlow89/siggy.jpg
flyinlow89 is offline   Reply With Quote
Old 08-01-2017, 10:04 AM   #5
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I like to wrap one of my thinner microfibers around an interior trim removal tool and work that through the crevice.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 08-01-2017, 01:33 PM   #6
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Always tape before polishing. Its a pain but it will save you from work later.
Edit: Try Mother's Detail brush(es) that come in a pack of two.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 08-01-2017, 04:07 PM   #7
jrhagen
Banned
Drives: Camaro
I use Q-tips.
jrhagen is offline   Reply With Quote
Old 08-01-2017, 04:32 PM   #8
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Stick the edge of a microfiber towel in your mouth and get it a little wet, then slide it through the crack to get most of it. If any is left over a q tip would work great
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 08-01-2017, 04:54 PM   #9
chuckie669
chuckie669's Avatar
Drives: 2011 ss
I was gonna say q-tip but the math man already summed it up well.
chuckie669 is offline   Reply With Quote
Old 08-01-2017, 09:55 PM   #10
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
bought this retractable brush from autozone that works for me. the other end has a rubber point thing that rubs wax out of crevices.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is offline   Reply With Quote
Old 08-02-2017, 02:14 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I use a Detailing tool just like this - it has a rubber tip on one end the a brush on the other.
Old 08-02-2017, 02:28 PM   #12
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Q-Tips, and you can still find with wooden sticks, with some denatured alcohol should do it with a follow up of soap and water.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-30-2017, 06:11 PM   #13
gofast908z
gofast908z's Avatar
Drives: Camaro
^ this.
Also popsicle sticks wrapped in a thin microfiber + detail spray usually work wonders in areas that are hard to reach and you need a tool that is rigid and flexible at the same time.
Jeff
2008 Z06 - Heads/cam/intake/exhaust/tune
2005 Sierra STL ext cab -5.3L, Daily/Detail Rig
gofast908z is offline   Reply With Quote
Old 08-31-2017, 08:22 AM   #14
moons21
moons21's Avatar
Drives: 2015 2SS/RS Convert
Keep in mind that if you use an APC or IPA that will strip the sealant and wax from the car and you should reapply the protection to those areas afterwards.
moons21 is offline   Reply With Quote
