Old 08-03-2017, 06:08 AM   #1
rtist
Drives: 2012 Camaro Lt
Transmission Fluid Change??
I have a 2012 Camaro Lt (V6 Manual).
@ How many miles should the Transmission Fluid be changed?
I looked in the service manual but nothing specifically stated that i should be changed @ so and so miles.
I did see chevy's site that said @ 45,000 miles on an automatic transmission.
But didn't say if that applies to a manual transmission.
Any ideas? Also what's the difference between changing the transmission fluid and flushing it? isn't flushing also changing the transmission fluid?
rtist is offline   Reply With Quote
Old 08-04-2017, 03:41 PM   #2
rtist
Bump! - any ideas guys :(
Old 08-04-2017, 03:51 PM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
It's super easy to do, and it doesn't hold much. I do it every 3 years or 30,000 miles.
Same fluid goes into the DIFF too, so I would do that at the same time and use the same interval.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 08-04-2017, 11:19 PM   #4
rtist
Is this accurate?
Also what's the difference between a transmission fluid change and a flush?
Would this be the correct steps?
Old 08-07-2017, 10:47 AM   #5
ChibiBlackSheep
Originally Posted by rtist View Post
Is this accurate?
That video looks accurate to me. Like I said, it really is easy to do this. Same for the rear diff. For the rear diff, you don't even use a socket, you just use the box end of a 3/8s ratchet.
A fluid change is just a drain and refill like you just saw. A flush is when a transmission is hooked up to a machine, where they flush fluid in one direction and out the other with more force than just gravity. A flush isn't necessary if you keep up with the routine fluid changes.
Just like how you don't need to flush an engine, just gravity change the oil.
If you buy 3 quarts of gear oil, and a fluid pump, you can get the trans and diff done in an hour or so.
I bought 3 quarts of this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I used this pump (but it didn't fit the quart bottle very well): https://www.amazon.com/Plews-55001-L...P6A6PXV40CPE02
And I added this GM fluid to the diff: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
~2 quarts for the trans, and ~1 quart for the diff.
Old 08-07-2017, 03:46 PM   #6
rtist
@ChibiBlackSheep
I see. Thanks man you've been a lot of help!
Old 08-07-2017, 04:04 PM   #7
ChibiBlackSheep
Glad I could help!
Old 08-07-2017, 05:38 PM   #8
rtist
Glad I could help!
1 Quart for the rear diff but what fraction of that is the additive? is it all of it?
Old 08-07-2017, 09:16 PM   #9
seishuku
Drives: 2011 Camaro LS
Manual says 1 quart plus the 2.5oz of friction modifier
seishuku is offline   Reply With Quote
Old 08-07-2017, 10:02 PM   #10
Gonzo SS
Gonzo SS's Avatar
Drives: 2012 IBM 2SS/RS LS3/M6
I did mine recently and used Royal Purple:
https://www.amazon.com/Royal-Purple-...dp/B001DKTG0G/
It's expensive and I thought I may have been buying some snake oil, but I can definitely tell a difference. Much smoother especially 1st to 2nd at high rpm's.
Stainless Power LT Headers, K&N Typhoon CAI, VMAX Ported Throttle Body, Jannetty Tune, Phastek Scoop & Washer Bottle Relocator, VTC
Resonator Delete w/Flowmaster Super 10's, BMR Lowering Springs, Koni Orange Struts, Factory Hurst Short Throw Shifter, Skip Shift Eliminator, DRL & Halo Harness, Window Valet
Scosche Kit w/Pioneer AVH-4100NEX, Lloyds Custom Mats, Blue LED Footwell Lighting
Gonzo SS is offline   Reply With Quote
Old 08-08-2017, 12:00 PM   #11
ChibiBlackSheep
GM recently changed it to 3oz recommendation I believe. I poured 3 oz in, and then filled the diff with fluid until it flowed out.
I've noticed a huge difference just getting the stock fluid out. For how easy this is to change, I don't mind doing it frequently and sticking with Mobil 1. You honestly can't go wrong just getting a new fluid in there.
You will be amazed at how dirty the original fluid is, and how much metal is on the magnets.
Old 08-08-2017, 12:21 PM   #12
rbenotti
rbenotti's Avatar
Drives: '13 LS, '09 Forester, '11 HD SGlide
Going to have to check those videos out. If it's not hard to do.....
2013 Chevrolet Camaro LS - M6
2011 Harley Davidson Street Glide
2009 Subaru Forester - M5
rbenotti is offline   Reply With Quote
Old 08-08-2017, 03:00 PM   #13
ChibiBlackSheep
It really isn't! If you are comfortable enough doing an oil change, you can change the trans and diff fluid on these cars.
Old 08-08-2017, 03:31 PM   #14
rtist
Awesome you'll. I'' be doing the transmission change probably tomorrow and I might upload a video or some instructional pics just in case another noob rolls around lol
Upload all your photos for free at
www.fb.pics .
For Free : No Charge : No Subscriptions
camaro, fluid, manual, transmission
