Old 08-04-2017, 11:05 AM   #1
matar123
matar123's Avatar
Drives: 2012 Camaro 2SS Ls3 Cammed/Blown
Anyone ever had this problem?
So I just got back from visiting family out of the country. I've been gone for about a month my car has been sitting in its canopy it has been started but not drivin now when I take it on the freeway any speed over 50 it's start vibrating and the steering wheel shakes and it get worse until about 70. Anyone know what this could be?
Thanks in advance
matar123 is offline   Reply With Quote
Old 08-04-2017, 11:12 AM   #2
WltrWht
WltrWht's Avatar
Drives: 2015 Summit White LS3
Flat spotted tires from sitting can sometimes do this, but usually correct themselves pretty quick.
WltrWht is offline   Reply With Quote
Old 08-04-2017, 11:14 AM   #3
matar123
matar123's Avatar
I've already drivin the car about 50 miles still does it
Old 08-04-2017, 12:51 PM   #4
ron123
ron123's Avatar
Drives: 2014 2SS/RS
1. Did you check the air pressure?
2. Are you sure the relatives that started up your car to let it idle while you were gone were not out joyriding? (few can resist)
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 08-04-2017, 12:52 PM   #5
matar123
matar123's Avatar
Ya I made sure the front tires had air in them it feels like the shaking is coming from there and I'm 100% sure no one drove it
Old 08-04-2017, 01:17 PM   #6
charles71
charles71's Avatar
Drives: 2011 Camaro SS
check for loose suspension parts and if all is tight then it may be your rack and pinion. Happened to a friend and that was his problem
Livernois Stage II Heads & Cam, LS7 Lifters, Ported Intake & Throttle Body, Rotofab CAI, BBK High Flow Fuel Rail @ Guage, Eaton Tru Trac Posi with 3.91 gears, 1000 HP Axels, Kooks Long tubes & full Corsa Exhaust, GM Hurst Short Throw Shifter, Mcleod RXT Twin Disc, Vitesse Throttle Controller, 1.5" Lowering Springs, Strut Tower Brace, SLP 25% Underdrive Pulley, Apex reservoir relocation kit and air scoop.
charles71 is offline   Reply With Quote
Old 08-04-2017, 01:32 PM   #7
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
This and have any leaks under car?
DvKillar is offline   Reply With Quote
Old 08-04-2017, 01:51 PM   #8
matar123
matar123's Avatar
No leaks. Is it possible that the tires got permentaly flat spotted?
Old 08-04-2017, 02:21 PM   #9
DvKillar
DvKillar's Avatar
modern radial tires.. highly unlikely for just sitting a month.
Old 08-04-2017, 02:38 PM   #10
Reddog1982
Drives: 2012 L99 2SS
If it's predictable- meaning shake at an exact speed up to another exact speed, in your case 50-70 then your tires need rebalanceing. You've likely lost a wheel weight somewhere.
Reddog1982 is offline   Reply With Quote
Old 08-04-2017, 02:51 PM   #11
matar123
matar123's Avatar
I'll take them to get rebalanced and see what happens
Thanks everyone
Old 08-04-2017, 02:57 PM   #12
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
I would be highly shocked if a month of sitting caused a flat spot that bad. Especially if the tires were aired properly.
Plus you should notice it before you got to 50 if they were.
Hope it's nothing major!
go_go_gadget88 is offline   Reply With Quote
Old 08-04-2017, 03:39 PM   #13
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Did you note the mileage? Possible damaging 'joy ride?'
Moto-Mojo is offline   Reply With Quote
Old 08-04-2017, 03:49 PM   #14
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
At the dealership I would have them do a road force balance. It will show if the tire is simply out of balance, has a flat spot or is out of round.
JerTM is offline   Reply With Quote
