![]() Drives: 2018 ZL1 1LE Join Date: Feb 2009
Zo7 CCB Pads...
Did a few searches and came up empty....
Do the Z07 Pads for the CCBs also fit our Z/28 Brembos? Appears they are different AC part #'s: 171-1010 F and 171-1143 R for the vette vs. 171-1132 F and 171-1134 R for our Z/28's Anyone know?? I have someone looking to sell some extra Z07 pads (he sold his vette). Thanks.
2018 ZL1 1LE "RAZECAR" 2016 2SS Convertible "NOTOPSS" (Sold) 2015 Z/28 #306 "ITZFAST" 2010 2SS Coupe "FASSTER" (Sold) 2002 SS/RS "02FASST" (Sold) 2007 Factory Five Racing GTM "REDBLUR" (Sold) "There are two kinds of cars. Red....and everything else!" |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE Join Date: Jul 2012
Well I don't know if they are the same or not but as a quick and easy check for physical size it's not too much work to pull a wheel and pop out your pads to see if the ZO7 pads fit into the caliper properly or not. That would only leave pad material as a potential difference.
I won the internet once
Drives: 1999 Honda CR-V Join Date: Sep 2015
Can the parts department give you physical specs?
Maybe an online parts house may have them? Try Brembo?
I want black smoke to come out when I gun it.
I also just went out to Hawk Brakes website and searched for pads for both the Z/28 and ZO7 and it listed their profile number for both as the same number. Which means they are using the same pad shape for both vehicles indicating the same pad can be used in both vehicles.
#5 | |
I can't compare them live (I don't even need to pop any of my Z/28 pads out....I have the used ones I changed out this week at Autobahn) as I don't have the Z07 pads here locally - my friend is near Autobahn in Joliet. I texted him pics of the back of the used pads as I would expect the Brembo #'s to match up. We shall see. Thanks again for the help. I'm driving the Z pretty hard these days and going through pads quite quickly - would be nice to get some stocked up.
#6 |
![]() Drives: Nothing Fast (Yet) Join Date: Oct 2015
The Z28 brakes are exactly the same as the C7 Z06/07 carbon ceramics, so theoretically, they should be able to use the same brake pads.
#7 |
![]() Drives: 2017 Buick Enclave Join Date: Jul 2016
The pads should be interchangeable; the difference probably is the pad censor.
#8 |
![]() Drives: Z/28 Join Date: Oct 2015
My friend has a ZO7 and the pads are exactly the same down to the Brembo PN. The only difference is the sensor.
#9 |
Drives: Camaro Justice Join Date: Jun 2007
The pads are interchangeable.
#10 |
Thanks all. Yep, they are the same Brembo # and pad and I'll be picking up some new pads (and a few other items) as he returns his Z07 to stock and sells it.
Appreciate the help.
#11 |
Runs with scissors...
Drives: '14 Z/28s SIM/SW Join Date: Jan 2013
My SM says they're the same, except for the length of the sensor wires. Just in case others haven't seen this, here's another source for our CCB pads:
FRONT: https://smile.amazon.com/dp/B00KUL9J...=1VRJZYUY3O46J REAR: https://smile.amazon.com/dp/B00KUL9K...=1VRJZYUY3O46J
