Old 08-11-2017, 02:45 AM   #1
Zgunth
Drives: 2012 Camaro 1LT
Maintenance for a 2012 V6
So I'm moving and will be going from using the camaro (a 2012 1lt) as a daily driver to a vehicle I don't plan to drive more than once a week. That drive will be fairly long, roughly 30-45 minutes there and back, but besides that it will be sitting in a garage that will average 65-70 degrees in temperature. What I'm worried about is a). If it will negatively affect the car being driven so infrequently and B). How do I know when to get the car serviced (oil change etc.). Is it bad in any way for the car not to be driven that often and will going about a week in between drives cause the battery to have issues or anything? And again, how often do I get the car serviced and the oil changed, and is the engine oil level readout reliable if I'm not constantly driving the car?
Thank you for your help!
Zgunth is offline   Reply With Quote
Old 08-11-2017, 06:36 AM   #2
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
Your car will be fine , I may use my car maybe Ince a week and sometimes it sits for two months at a time, I may start it up more due to my colder climate. You may want to invest in a battery tender as well. Since your driving it once a week you will not have to worry about flat spots on the tires and even if that does occur you drive a few miles and that issue goes away. As for the oil change, I did mine last oct, run full synthetic and I am still not due, 5k interval. But imo oonce a year it should be changed. But some will say otherwise and they have no issues as well.
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 08-11-2017, 05:52 PM   #3
Zgunth
Thank you! From what I had seen I wasn't too concerned but it really does help to hear from someone who is in a similar position as me.
