08-13-2017, 03:29 PM | #1 |
Drives: 2019 CMGM 1LZ Z06, R.I.P 2014 SIM 1 Join Date: May 2015
Front tire size
Anyone know what front profile size I need so my abs light doesn't go off like crazy right now??? I got Michelin PSS 315/35zr20s in the back and have PSS 285/30zr20s in the front ... I know bad choice learned the hard way, so now if I go with the PSS 285/35zr20s in the front would the difference between them be close so the abs system doesn't flip out??
Thanks in advance https://m.tirerack.com/tires/Spec.js...um=835YR0PSSXL https://m.tirerack.com/tires/Spec.js...um=135YR0PSSXL Last edited by OmarSS; 08-13-2017 at 04:18 PM. |
08-13-2017, 05:29 PM | #2 | |
Drives: 2010 SS Camaro Join Date: Oct 2008
08-13-2017, 06:12 PM | #3 |
Drives: Miss Con Ception Join Date: Aug 2016
275/40X20 is the same diameter as the 315/35. 285/40 will be a bit taller.
2011 1SS/RS LS3 CGM
08-13-2017, 06:30 PM | #4 | |
So I was looking around and found this tire down below. https://m.tirerack.com/tires/Spec.js...artnum=84YR0P0 So I shouldn't have no more problems right? Thx again gonna wait a few weeks but eventually will pull the trigger on new fronts... the Christmas light dash is annoying! |
08-13-2017, 06:38 PM | #5 |
Hi Fred so what would you recommend should I go down to a 275/35/20, 275/40/20? or will the 285/35/20 michelin PSS I listed in the first post do the trick, would like to stay with a 285 but they don't make a PSS In a 40... only one that caught my eye was the pirelli tire I listed to Craig... I wanted to stay with the same front/back tire brands but like I told Craig if I don't have a choice I can live with different brands. Thank you
08-13-2017, 06:45 PM | #6 |
Would like to keep the rake almost or as close too the same tho that may not be possible, but I come from the stock SS 40/45 tire size so no biggie if one size is a little bigger
08-13-2017, 07:59 PM | #7 |
Was looking at the recommended tire size thread and yup it said for a 285 a profile of 40 is recommended, so looks like pirelli will be the one I go with! Thx all again
08-13-2017, 08:03 PM | #8 |
Drives: 2010 1LT v6 Twin Turbo Join Date: Jun 2010
chart
good info.
https://www.ohio-speed.com/p-6852-re...rim-sizes.aspx you welcome! jim ohio-speed.com 440-813-2490 |
08-14-2017, 02:22 AM | #9 | |
It looks like you found your solution. The 285/40 is ~0.15" larger radius than the 315/35 so you should be good.
245/45 = 14.34" radius 275/40 = 14.33" 285/40 = 14.49" 315/35 = 14.34" Mathematically. Manufacturers can produce slightly different actual sizes.
2011 1SS/RS LS3 CGM
08-14-2017, 08:18 AM | #10 |
Drives: 2014 2SS blue Join Date: Jun 2016
Looking at the Tire Rack data for the Mich PSS, the 295/35ZR20 comes in at 28.1" dia which is a little closer to the 315/35ZR20 (28.7" dia).
The 285/35ZR20 is listed at 27.9" dia. The 275/40ZR20 is a direct match (28.7" dia) to the 315/35ZR20.
08-14-2017, 11:53 AM | #11 |
Bro do you think the 295/35/20 PSS will rub up front? My car is not lowered, stock height my rim offset is 32 thank you!
08-14-2017, 11:55 AM | #12 | |
