Old 08-15-2017, 12:23 PM   #1
Frostbite13
Frostbite13's Avatar
Drives: '13 2ls
Smile Coilovers help
looking for coilers around the $1000 mark and i also want to be able to slam the car to the ground,(lower it more than 2.5 inches),what would my options be?
Frostbite13 is offline   Reply With Quote
Old 08-15-2017, 12:54 PM   #2
Avenging Orange
Avenging Orange's Avatar
Air
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 08-15-2017, 05:10 PM   #3
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Look at BC Racing coilovers
SSEssence is offline   Reply With Quote
Old 08-15-2017, 08:57 PM   #4
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Also thinking about further suspension modifications. What would be the point in choosing coilovers vs. something like JPSS offers with the Bilstein B6. Trying to figure out what route to go. Looking to lower car 1'' max.
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 08-19-2017, 12:00 AM   #5
GLEE
GLEE's Avatar
Drives: 2014 2SS/RS
Talk to JPSS. DSSV unless youre going to spend over 5k on coilovers
GLEE is offline   Reply With Quote
Old 08-19-2017, 08:10 AM   #6
KillboyPowerhead
Drives: 2015 Z/22
Main advantage of coil-overs is that you can adjust - depending on how expensive they are - both spring rate and damping rate to almost perfectly balance your car for your particular driving habits, roads, etc. With that said, to gain full adjustability (height, spring rate, compression, rebound) you're looking at 4 - 5 g's typically for a good set of coil-overs - this is where separate springs/shocks come into play because they will be much cheaper while still providing an improved ride over stock.
JusticePete seems to like to the Bilstein B6's with BMR or DSE springs combo; I gotta think the Bilsteins would go well with most lowering springs available for the Camaro as they tend to be somewhat similar in spring rate (I think?); according to Bilstein the B6's are built specifically for a particular car (with stock springs); so, unless you can to spend 4 - 5k as mentioned above or have a dedicated race car you'll probably be well enough off with the B6's + lowering springs.
You can also get less sophisticated coil-overs with less adjustability for cheaper, however, JP recently said that unless you spend the $ to get the full adjustability then the B6's + BMR/DSE springs will be very comparable, and I tend to listen to what he says
KillboyPowerhead is offline   Reply With Quote
Old 08-19-2017, 09:17 AM   #7
sspade
sspade's Avatar
Thanks for clarifying that!
B6's it is... will look into springs now. Only looking to lower car 1' - any suggestions on springs to match the Bilsteins?
Old 08-20-2017, 01:07 PM   #8
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
It's hard to beat Ridetech coilover for the features and price. Mr. Pete has said similar.
More to come.
Black_SS10 is offline   Reply With Quote
Old 08-20-2017, 04:51 PM   #9
sspade
sspade's Avatar
Ridetech's are sweet but for well under half the cost you can get Bilstein B6 and BMR springs. That's the route I'm leaning towards.
Old 08-21-2017, 11:40 AM   #10
Zombie killer
Emerald Coast Camaros
Zombie killer's Avatar
Drives: 2013 2SS/RS L99
Bilsteins and lowering springs are not a bad choice and are a good value for better handling unless you can utilize the full adjustability that a good set of coil overs could offer. I am running the B6s and 1" lowering springs with a heavy rear bar and they perform very well for the money spent. Body roll is minimal (see photo) and the front grip is very good.
Zombie killer is offline   Reply With Quote
Old 08-21-2017, 01:09 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I should have some Coilovers from Viking Performance soon
Old 09-12-2017, 10:29 PM   #12
Camee6
Drives: 2010 Camaro
According to Bilstein the B6's are built specifically for a particular car (with stock springs); so, unless you can to spend 4 - 5k as mentioned above or have a dedicated race car you'll probably be well enough off with the B6's + lowering springs
Glad to know this info about Bilstein. Has anyone here tried the H&R lowering springs?
Camee6 is offline   Reply With Quote
Old 09-14-2017, 11:06 AM   #13
Ghost52
Ghost52's Avatar
Drives: SW 2SS/RS L99
LG Motorsports has a set for under $1395.95, but that is really all I know about them..
Ghost52 is offline   Reply With Quote
Old 09-14-2017, 11:52 AM   #14
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
What is your purpose for them, for looks and daily driving? Or are you going to be on the track with them? There are some less expensive ones out there. Just be careful and strongly consider the purpose of them. Check these out.
gabe
Sales@Phastek is offline   Reply With Quote
