08-17-2017, 12:37 AM | #1 |
Drives: 2015 1LE Camaro Join Date: Apr 2015
Rear wheel arch dent/ding removal?
Hi Guys
I have a small ding on the left REAR wheel arch, but I understand this area MIGHT be inaccessible due to the double skinned wheel arch area. (I'm getting conflicting info about where the double layer starts/ends). Does anyone know for sure if the location of this dent is concealed by the double skinned wheel arch area? And if so, would removal of the rear bumper/tail light give access to the back of the panel? Thanks |
08-17-2017, 11:16 AM | #2 |
Drives: 2015 2LT RS Join Date: Feb 2015
Have you thought about heating it up and then placing an ice bag on it? May just pop it out, instead of removing the inner wheel well. Just a suggestion.....
It is what it is!
08-17-2017, 11:25 AM | #3 |
Just an average Dude
Drives: 2015 1LT Grey w/Orange Rally Stripe Join Date: Mar 2016
I'm not sure but you might be able to use a suction cup to pull it out.
or from inside the trunk
So far I like my car the way it came from the factory.
08-17-2017, 11:28 AM | #4 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
My advice to you is to contact a paintless dent removal tech and have him decide if he can or cant fix it. And if he can repair let him do it. They do great work.
08-17-2017, 03:28 PM | #5 | |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
even if you push it out yourself you may stretch the metal and it will still be wavy. $100 they will probably fix that |
08-17-2017, 05:02 PM | #6 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
Ask a dealer which PDR guy they use. They work with only those that does great work.
08-17-2017, 10:16 PM | #7 |
SoCal C5 Family Member
Drives: 1996 Z28 SS & 2014 ZL1 Join Date: Apr 2009
Totally fixable with paintless dent removal.
I had a dent removed at the very top corner of the flat portion of the wheel arch. The PDR guy said that if it was any lower, he would not be able to fix it.
Vance Chula -
1996 Camaro Z28 SS #1688 2014 Camaro ZL1 Coupe #1956 |
08-18-2017, 09:43 AM | #8 |
Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
Yes, call a pro. Not much $. They have special tools that will pull that out.
A guy pulled out a dent on the corner of my truck cab once. I could not believe it! |
08-18-2017, 01:38 PM | #9 |
Drives: 2013 1LE/SS Join Date: Mar 2012
That can be fixed using pdr process. Take off the interior plastic panel cover inside the vehicle, and there is a huge factory hole for access. Whale tail or hockey stick pdr tool to remove dent.... I'm a PDR tech
Current mods: Stainless Power Long Tube Headers,Cat Delete,CAI Cold Air Intake,Vitesse throttle controller, Muffler/Resonator Delete w/dual tips. ADM Performance Tuned,BMR 1.25 lowering springs,R1 Concept Slotted/Dimpled Rotors.
08-19-2017, 01:22 PM | #10 |
I had one PDR guy come to check it, he was perhaps just not great, but was unsure of getting it out due to access.
Texas RS- any plans to come to So Cal?! I'll use your PDR services! |
08-19-2017, 07:37 PM | #11 |
Got it out with another PDR guy. What a relief. I found this pic online and we got access to the back of the panel (see arrow in green) to get the dent out completely.
I'm also posting a pic of the access hole from the interior that Texas RS mentioned. Hope the pics help someone. |
