08-24-2017, 07:49 PM | #1 |
Drives: Black 2013 ZL-1 Join Date: Jun 2017
hulk hogan steering
out of the blue i went to start my zl1 and the steering wheel was 180 degrees from normal position.. idiot light flashed "service power steering" ..i checked the fluid level in reservoir but it wasn't there.. i guess things have changed from my jeep yj days. why is my electric power steering fried? ..70,866 total miles.had to use my 24" pythons to muscle my way home..
08-24-2017, 08:15 PM | #2 |
Drives: Fast Join Date: Mar 2015
Gonna need pics of those 24" pythons heheheh
Get it to a dealership if you can safely, if you can't, tow it there. 70,000 miles is quite a bit if it's been driven hard, and stuff is going to start getting worn down. Last edited by Can'tHave2MuchHP; 08-25-2017 at 03:22 PM. |
08-24-2017, 08:34 PM | #3 |
wait,..what?!?
08-24-2017, 09:45 PM | #4 |
Drives: 2013 ZL1 Join Date: Jan 2015
There are posts about the electronic power steering. Often it's a loose ground. Google and you should fine some good info.
2013 A6 ZL1
08-24-2017, 10:28 PM | #5 |
KaBoom1701
+1
Mods:
08-25-2017, 05:26 AM | #6 |
Drives: 2013 zl1 Join Date: Aug 2017
70k is quite a bit and stuff is going to start breaking , what did he buy a Ford in the 80s?
08-25-2017, 10:09 AM | #7 | |
-Former dealership service manager |
08-25-2017, 10:58 AM | #8 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
So power steering failures are not so uncommon, and might be partly caused by weak ground connections. |
08-25-2017, 11:41 AM | #9 |
Drives: 2014 ZL1 Join Date: Apr 2013
Not just weak ground, but seems other electric items can cause issues as well. I added on the autoblip, not sure if it is not installed correctly (although it does work) but with it on, I will get the service power steering message after a bit. Haven't touched the main ground to the chassis, only the wires needed for the autoblip. Could be anything electric it seems.
08-25-2017, 11:59 AM | #10 | |
08-25-2017, 12:02 PM | #11 | |
08-25-2017, 06:43 PM | #12 | |
2013 A6 ZL1
08-25-2017, 06:51 PM | #13 |
Um when the original post pertains to the power steering taking a shit OK a 70k mi car , this isn't normal wear and tear. Something failed. Whether a fuse blew, electric motor took a shit, bad ground, etc... Something failed. Wear items may need to be replaced at this kind of mileage that should be all. Stuff isn't wearing out at 70k mi when cars are built to run 200k+ miles and if this is how you feel vehicles are then you must be used to buying junk. A "around" ( so we don't get technical here" 70k Chevy will not be wearing out such items like these.
08-25-2017, 06:52 PM | #14 |
On a 70k mi car*
