Old 08-25-2017, 07:11 AM   #1
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
Dead Batteries
I've had 2 dead batteries since I bought my Camaro in 2010. After replacing the battery the engine cranks over slower and slower over time.
I'm wondering if I need a higher amp alternator due to the added strain of the supercharger? Anyone else experiencing this issue or have upgraded the alt or battery?
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 08-25-2017, 07:40 AM   #2
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Hmm, I had a TVS-2300 on the car for 6 yrs and no issue with battery drain due to excess current draw. Sort of sounds like you have a problem with your electrical system that possibly could be detected by someone with the right diagnostic equipment?
Wish I was more help. Keep us posted please.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 08-25-2017, 07:46 AM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
what kind of batteries? AGM? clean all your grounds and double check all of the aftermarket connections...any codes? try and get a scan and look at the bcm....good luck...
Old 08-25-2017, 12:57 PM   #4
Missile Man
I've been told that living in very hot locations can reduce the life of the battery significantly. I live in Las Vegas and moving to AZ next month so we'll see. There's no corrosion any where on the battery and the clamps were tight. After I move I'll check for current flow on the battery when the car is off.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 08-25-2017, 01:19 PM   #5
xc_SS/RS
Drives: 2010 Camaro SS/RS
check your starter connection. could be nasty and not providing the best contact/connection
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 08-25-2017, 11:51 PM   #6
-Im.z2ight-
Drives: 2013 Camaro 2SS "Diablo"
I had a similar issue and last sunday it decided to just not start. I think a ground slowly got loose somewhere. I ran a new ground and its working just fine again.
Diablo - 2013 Camaro 2SS
Mod List: GM NPP Dual mode exhaust(Fuse pulled), AGP Twin Turbo 54/57, ZL1 Fuel pump with flex fuel sensor, ADM FPCM, ID1000 Injectors, diamond racing forged pistons, BTR twin turbo cam stage 2, Lunati forged H beam rods, BTR trunnions, ARP head studs, Vararam power wedge, MightyMouse Wild catch can, PFADT 1.25" drop springs, BMR Strut tower brace, 20x10.5 Giovanna Mecca rear and 20x9 Giovanna Mecca fronts, R1 Concepts drilled and slotted rotors, Hawk HPS pads, Night Owl RGB halo kit, and more...
Future Mods: Dual fuel pump and more...
-Im.z2ight- is offline   Reply With Quote
Old 08-26-2017, 08:25 AM   #7
Missile Man
It's the stock OEM battery, no codes. I need to look at the supercharger intercooler pump connections.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 08-26-2017, 11:34 AM   #8
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
Any other mods? Taillights, or anything that connects to the OBD connector under the dash?
FrankT is offline   Reply With Quote
Old 08-26-2017, 12:39 PM   #9
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Was an undersized crank pulley included in the supercharger install?
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-26-2017, 08:12 PM   #10
Missile Man
All my mods are HP related. Just the intercooler pump.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 08-27-2017, 05:17 AM   #11
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
I had a similar problem with slow cranking on my supercharged L99, I fitted an MSD Dynaforce starter and problem is solved.
Search MSD starter for my thread.
Stubbsy is offline   Reply With Quote
Old 08-27-2017, 12:39 PM   #12
Missile Man
Do you happen to remember the MSD part number? I didn't find your link.
2010 Black 2SS L99
Mods:
* CAI Intake
Old 08-27-2017, 02:42 PM   #13
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
Part number is 5096. Just search MSD Starter it was only a few weeks ago.
Old 08-27-2017, 02:49 PM   #14
Missile Man
Thanks! Found the link, nice.
2010 Black 2SS L99
Mods:
* CAI Intake
