Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 08-25-2017, 08:59 AM   #1
sspade
sspade's Avatar
Drives: 2015 Camaro LFX A6
Elk Grove
Just wondering if anyone is from the Elk Grove area? Just moved here about three weeks ago. Seen a few Camaro's on the streets near my house. Anyone here?
Cold Air Inductions CAI : Apex Air Scoop / WW Relocate Kit : JacFab Intake Manifold Spacer : Overkill 80mm Throttle Body : Overkill Tuned : MagnaFlow Cat-Back Exhaust : Elite Engineering Catch Can : ZL1 Strut Tower Brace : Custom Tunnel Brace : JPSS Caster Locks : JPSS 32mm Rear Sway Bar : JPSS Billet Radius Arm Bushings : Pegasus Solid Sub Frame Bushings : 1LE Brembo Conversion : B&M 70273 Trans Cooler
sspade is offline   Reply With Quote
Old 09-05-2017, 09:42 PM   #2
hkittrell
hkittrell's Avatar
Drives: 2015 Camaro 1SS/RS 1LE
I'm in midtown.
hkittrell is offline   Reply With Quote
Old 10-27-2017, 10:12 PM   #3
BruHop
BruHop's Avatar
Drives: 2014 2SS 1LE,RS,NPP,Recaros in SW
Granite Bay
BruHop is offline   Reply With Quote
Old 10-28-2017, 12:15 AM   #4
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
Up the hill in Rescue
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 10-29-2017, 01:32 PM   #5
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
El Dorado Hills.
Ramir with his BeastMode (Laguna? blue) is from Elk Grove
Shez with Toothless/Nightfury (black with neon green accents) is from Elk Grove
Both are 5th gen ZL1s.
There are a large number of forum members in the area though. Welcome to the neighborhood!
