Old 08-25-2017, 10:04 AM   #1
CJG
CJG's Avatar
Drives: 2018 1SS M6 Summit White, MRC & NPP
Transmission problem?
Hi guys - I've been noticing an odd noise and can't find any prior threads on the issue. I have a 2011 SS M6 with 46k miles. I've noticed that at low speeds (between 5-10mph) while in first gear making a turn, there is a rubbing noise. This only happens when I maintain that speed (i.e. driving around a culdesac). It's especially apparent if the car rocks back and forth a bit while in gear. Sounds like it's coming from the rear end. Anyone have any ideas before I bring it to the dealer?
CJG is offline   Reply With Quote
Old 08-25-2017, 10:26 AM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
May be something as simple as needing a differential service done. At your mileage you are due if it hasn't been done yet.
Old 08-25-2017, 10:29 AM   #3
CJG
CJG's Avatar
I did just have the rear diff fluids changed last week. Could this be it?
Old 08-25-2017, 10:34 AM   #4
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
1st has gears that are more straight cut than the other gears so there is more play.
Start in 2nd or shift to 2nd as soon as you start rolling if you don't need the acceleration 1st provides.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-25-2017, 10:38 AM   #5
CamaroFred
CamaroFred's Avatar
Sorry, I missed this while I was making my previous post.
Go to a parking lot and make figure 8s. That will distribute the fluid to the clutch packs. The mechanic should have done this when the fluid was changed.
2011 1SS/RS LS3 CGM
Old 08-25-2017, 10:59 AM   #6
SlingShot
SlingShot's Avatar
Yes, go find a parking lot and do a dozen figure 8's, sounds like it needs to be broke in again. Modern oil has the the LSD additive in it, so that shouldn't be the issue. If it keeps it up, check with dealer or where ever you had the work done at about the additive.
Old 08-25-2017, 11:25 AM   #7
CJG
CJG's Avatar
Thanks, guys! Just did a few figure 8s and the noise has almost completely vanished. Thanks again!!!
Old 08-25-2017, 11:59 AM   #8
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Check your invoice to make sure the Limited Slip Additive was included in the service. My dealer missed it the first time and my rear diff groaned quite a bit. I looked up the fluid part # on my invoice and confirmed it didn't have an additive......Took it back and they did a new TSB that included a new fluid and axle seals as the fluid wasn't compatible with the new seals.
Doing figure 8's is part of the service to ensure the fluid gets out further......
qcman is offline   Reply With Quote
Old 08-25-2017, 08:04 PM   #9
CJG
CJG's Avatar
So after waiting a bit and driving it again, the noise came back. Going to have the dealer check on the additives.
Old 08-25-2017, 08:07 PM   #10
CJG
CJG's Avatar
I have an appointment on Monday. Is it harmful to drive it for the weekend?
Old 08-25-2017, 09:04 PM   #11
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I would avoid a long trip for sure, but a few miles here and there shouldn't be a problem. I'm thinking a rear hub/bearing or maybe even a caliper hanging up. Is it a metallic sound?
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 08-25-2017, 09:14 PM   #12
CJG
CJG's Avatar
It's not metallic, more of a rubbing sound. I checked my invoice and it looks like the dealer didn't add the Limited Slip Additive. However, the diff fluid change was done about 4 weeks ago, I hope there's no damage.
Old 08-25-2017, 09:39 PM   #13
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Depends which diff oil the dealer used.
Here's the history:
Diff fluid for 2010 Camaro V8:
75W-90 GM p/n 89021677
Friction Modifier GM p/n 1052358
Superseded by:
75W-90 GM p/n 88900401
Friction Modifier GM p/n 88900330
2017 Superseded by:
GM p/n88862624
No friction modifier required
Hopefully, the fluid part numbers are on your work order!
Rock-It Man is offline   Reply With Quote
Old 08-25-2017, 09:47 PM   #14
CJG
CJG's Avatar
The invoice shows the 88900401, but that's it. Should there be an additive?
