08-25-2017, 09:11 PM | #1 |
Drives: 2014 corvette Join Date: Oct 2016
Injectors? And pulley?
So thought I had a set of I'd 850's and that deal died. So as I work for gm and get. A good discount. Are there a set of stock injectors from like the zr1 Corvette or something I can swap too. .that will support the needs of more boost. I am torn. I am wanting to do the jre 75 kit. Just the price for the at damper and pulley. Upper is so much cheaper. And I see so many doing the upper pulley. So what advice can you give. ?
Mods so far are cold air intake and full catback Corsa exhaust. |
08-25-2017, 09:57 PM | #2 |
Also if I go upper. With injectors. Can I run a 2.4 upper without headers. ? If not what's the largest I can run without headers. Re-guardless jannetty will be tuning it.
08-25-2017, 10:11 PM | #3 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
08-25-2017, 10:13 PM | #4 |
So is there a set by gm to use. ?
08-26-2017, 09:01 AM | #5 | |
2.4 works out to 22% off the top of my head. You can run our 75 RWHP Package with LT headers we do it all the time. We never recommend changing the upper pulley as it induces belt slip. Always go after the lower pulley to change the speed of the supercharger. Our performance packages are engineered to give the best all around performance per dollar spent. Yes the Upper pulleys are cheaper but a boat load more work to install and there goes your 10 year 100,000 mile blower warranty. Thank you for choosing JRE, I am always available to answer questions via email tedj@jannettyracing.com or phone 203-753-7223 Ted.
www.jannettyracing.com
08-26-2017, 11:35 AM | #6 |
Drives: 2012 ZL1 A6 Join Date: May 2017
I just did an upper 2.38, ls7 throttle body, ported snout, id850's and flex fuel. I'm still running stock manifolds and catts. The car went from 486rhp to 594rhp and to 632rhp with 50% e85.
