Old 08-27-2017, 08:48 AM   #1
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
E85 conversion question
I've been researching the conversion and can't really find anyone with my exact set up. The 1le has the zl1 pump, so I should be good pump wise. My question is, do I need bigger injectors? If so, what should I get? Btw, it made 475/430 on a dynojet after the cam install. Mods in my sig...
I feel if all I need is the sensor and a tune, it's worth switching since there are plenty of stations in my area...and it's not a dd, so I'm not concerned about a change in fuel mileage. If I have to spend $1k on injectors, it may not make sense....
Thanks in advance!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 08-27-2017, 10:56 AM   #2
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
I have considered an E85 conversion too, but there has to be some acknowledgement regarding the current political climate. This administration likes oil, not clean energy. Theyre building pipelines. Also, farmers receive government subsidies to grow corn for E85 production. Subsidies are another thing this administration is against. So I have to wonder what the longevity of E85 is. If the subsidies are cut and the farmers stop growing corn, the price of E85 will go way up. Eventually there will be very few stations carrying it.
Im not saying, I'm just saying.
On the other hand, the conversion kit for my V6 is only $300, so its not a gigantic investment should the industry fail. Thus the reason I am on the fence. I already have a tune.
Jazzzed is offline   Reply With Quote
Old 08-28-2017, 06:14 AM   #3
DSX Tuning
Drives: 2019 Corvette ZR1
You'd want injectors, but something like used LSA injectors would be completely acceptable for your setup.
I've got kits available on www.dsxtuning.com.
DSX Tuning is offline   Reply With Quote
Old 08-28-2017, 06:41 AM   #4
Clarkstar
Clarkstar's Avatar
Thanks!
Old 08-28-2017, 06:18 PM   #5
Clarkstar
Clarkstar's Avatar
What lb injectors? I see many listed that say ls3, lsa,ls9, etc... what lb are stock ls3? And what do I need?
Thanks!
Old 08-28-2017, 06:23 PM   #6
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
definitely check out dsx, I am currently running his e85 sensor in my car, but to get the most out of e85 you will need a tune
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 08-28-2017, 06:53 PM   #7
Clarkstar
Clarkstar's Avatar
Yes, will get a tune... just want to make sure I got all the right parts on before the tune.
Old 08-30-2017, 06:19 AM   #8
DSX Tuning
LS3 flow around 40lb/hr. LSA/LS9 are 52lb/hr.
Old 10-06-2017, 12:03 PM   #9
suprchrgd
Drives: 2015 2SS 1LE
Are the lsa/ls9 injectors big enough on an n/a setup making are 500whp on 93?
Does anyone here know what the duty cycle is running on this setup, n/a, with e85 using the lsa/ls9 injectors?
Also, curious to what the average gains are by going to e85 on an n/a setup like ours?
suprchrgd is offline   Reply With Quote
Old 10-06-2017, 12:34 PM   #10
DSX Tuning
For NA, LSA/LS9 injectors are good to about 600whp.
Old 10-06-2017, 05:22 PM   #11
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
Do you keep your cash in the walls because you don't trust banks?
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 10-06-2017, 06:35 PM   #12
Jazzzed
Jazzzed's Avatar
Um, no? Do you have a closet full of Cabbage Patch Kids and Beanie Babies? Lol.
Old 10-06-2017, 08:21 PM   #13
Gunmetal Speedster
Holding onto them for a rainy day, the value has quintupled at this point.
Old 10-07-2017, 02:04 PM   #14
jc615
jc615's Avatar
Drives: Camaro and Sierra
You couldn't find anyone with your setup? There are a lot of cars on here with the same mods running Lsa injectors and zl1 pump. Think you were just being lazy
jc615 is offline   Reply With Quote
