08-27-2017, 03:23 PM | #1 |
Drives: 2015 1LE Camaro Join Date: Apr 2015
Heavyweight shift knob
Hi All
I put in a delrin cueball (plastic) shift knob into my 2015 1LE (its made by the main vendor people know of on this site) but it's too light: it makes the shifts feels even more notchy so I ended up switching back to the stock knob since its heavier than the delrin cueball. Recently I came across Raceseng- and Barton- who make heavyweight knobs for our cars. Has anyone tried them before? The first vendor has a range of weights and styles to choose from. The second has an aluminum cue ball style knob, but I think they might be able to make a heavier all steel one. Both have their own 3/4-16 thread adapter so you SHOULD be able to interchange the knobs and adapters between both vendors. Links below (I think for the second link, the Corvette C6/Cadillac CTS V is the same adapter setup we need): Let me know if anyone has tried these, or any other weighted setup? https://bartonshifters.com/shop?olsF...num-shift-knob http://www.raceseng.com/products/shift-knobs/cadillac |
08-29-2017, 07:12 PM | #2 |
Camaro Addict
Drives: 2010SS/1995 Z28/2005 CTSV/2007 TBSS Join Date: Jan 2007
Go for it. I have this setup on my CTS-V and the weight makes a HUGE difference! Plus it looks great!
08-29-2017, 07:23 PM | #3 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Yep, got the Black Pearl off twmperformance.com on my Hurst stick... just gorgeous... heavy, makes shifting feel like a hot knife through warm butter.
https://www.twmperformance.com/shift...ams-shift-knob |
08-29-2017, 09:53 PM | #4 |
Sounds great! I'm in touch with Jarrett at Raceseng who will confirm the CTS V/C6 Vette setup will work for Gen 5 Camaros and then I'm going to order one... Will keep you posted
01-25-2021, 08:37 AM | #5 |
Anyone have a Raceseng Shift knob on their Camaro 6 sp? Pricey, but heavy at ~1lb and looks good depending of the selected style. Or a similar heavy knob? Tired of the white lightweight cue ball on my Hurst Billet shifter, will require a 3/8-16 adapter. BTW - Twmperformance seems to be out of business.
01-25-2021, 06:56 PM | #6 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
I have the raceseng slammer. Love it. I’m adding an extender next week.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
01-26-2021, 06:09 AM | #7 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Contact epco shift knobs.
https://epcomfg.com/shift-knobs/ They have a long product line and will also make you a custom one. I had them make one for my 2013 ZL1. Was around $100.
01-26-2021, 06:36 AM | #8 |
Hey V-14:
Yeah, I like that one. Heavy at 1.4 lbs! I assume you have it installed on a stock shifter (press on and lock screw)? So would a "extender" just space the shift ball up higher, and not anything related to the fit at the boot interface? |
01-26-2021, 09:21 PM | #9 |
Valkyrie14
Right, I am going with the extender to raise it a bit. I could have put the adapter a little higher on the stock stick, but after seeing it on there I think the extender will look better. The adapter has like 5 screws that tighten down on the stick, which is flat on one side. The knob does not slide around at all. Took five minutes to install.
03-23-2021, 09:37 PM | #10 | |
Drives: 2013 1SS LS3 Join Date: Feb 2014
Also, any chance of seeing what it looks like from a side view? |
03-24-2021, 11:38 AM | #11 |
Drives: 2013 2SS Join Date: Mar 2014
A side view would be most helpful. I am considering this shift knob myself.
03-24-2021, 05:29 PM | #12 |
I just got an email from Raceseng stating that their shift knobs won't work with a 2013 Camaro. I'm puzzled, because I thought the shifters were the same 13-15 and we have a poster here with one installed on a '14??
03-24-2021, 09:10 PM | #13 |
Valkyrie14
Here is a pic with the extender. Pardon the unclean state of things.
03-24-2021, 09:26 PM | #14 |
