08-30-2017, 04:22 PM | #1 |
Drives: 2010 Camaro SS 2SS Join Date: Jul 2017
Hear water rushing through consol when starting
Normal?
6.2 SS 2010 |
08-30-2017, 04:28 PM | #2 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Following. I have the same thing sometimes. Sounds more from in the dash than console though. Almost like I can hear it flowing thru the heater core.
08-30-2017, 05:08 PM | #3 |
Drives: 2012 Camaro SS Join Date: Oct 2016
My old thunder bird make similar sounds, ended up being an air pocket in the heater core. I'd check the coolant system for sure. Try and bleed any air out of it.
Mine happened after a radiator swap. Was a 97 Thunderturd. Good luck in getting it figured out for sure though. |
08-30-2017, 05:09 PM | #4 |
Could be dash, just a lot of water going somewhere...
08-30-2017, 05:11 PM | #5 | |
08-30-2017, 06:08 PM | #6 |
My coolant bottle is empty, the radiator is a little low and I thought I smelled coolant when I turned the heater on the first time in forever.
Heater core? How can it be bad in 7 years? |
08-30-2017, 06:29 PM | #7 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
It is not normal, I would have your heater system checked out, especially if you are low on coolant & smelling it through your vents.
08-30-2017, 06:53 PM | #8 |
Yep, bummer. I'll presure test it and see where she looses presure.
Thanks, I didn't think you should hear water rushing around. |
08-30-2017, 10:36 PM | #9 |
Drives: 2017 50th Anniversary 2SS Camaro Join Date: Jan 2016
Yes. Air pocket in cooling system.
Sent from my SM-G950U using Tapatalk |
08-31-2017, 06:35 AM | #10 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
2010s have a history of heater core issues. And they're not easy to replace. Click on 'search' in the tool bar and just type heater core in the google search field and several threads will come up. There is also a TSB about it.
08-31-2017, 06:46 AM | #11 |
376 cubic inches of fun
Depends.
If your car has been outside in the rain, it could just be water draining from the tray under the cowl when you accelerate. If your heater is leaking, you will smell it. |
08-31-2017, 07:10 AM | #12 |
Drives: 2014 2SS MT, Convertible Join Date: Jun 2015
I think all years of the gen 5 have a lot of heater core issues. My 14SS had to be replaced...thank goodness done under warranty. Was 2 weeks in the shop, removed the console and dash, need to remove windshield to get out dash unless you are creative but the dealer isn't. They broke my windshield removing it so had to replace it too. I think they told me it would have been $2300 if I had to pay for the repair.
Steve
2014 2SS MT, Convertible Saint Augustine FL |
08-31-2017, 12:07 PM | #13 |
Turns out there is also a TSB for gurgling sound in dash on startup.
GM recommends a one way valve be installed in the heater hose to keep the coolant from back flowing. I know believe the heater core was damaged do to AIR in system. Dexcool does not do well with oxygen present, thing corrode. Wow, I'm bummed. |
09-05-2017, 08:50 PM | #14 |
Can you direct me to the TSB you are talking about?
