Old 09-03-2017, 04:33 AM   #1
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
4l80E 1/4 mile and street
I've searched the forum and found a bunch of threads talking about the swap itself but only one where someone mentions taking it to the strip. Anyone notice much difference on the strip with this swap? And how about on the street, let's say stoplight to stoplight. I'm thinking the only problem will be traction with my setup as she already spins.
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 09-03-2017, 05:54 PM   #2
Bo White
Bo White's Avatar
Look at the th400 posts and just add the fact of overdrive and a touch more weight.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 09-03-2017, 09:38 PM   #3
Blakester
Drives: 2010 1ss
This is another consideration of mine. I plan too go bolt on maybe nitrous And cam for quite a while. Will a th400 or 80e hurt me vs a driver mod and staying m6 since I won't be making a ton of power and the 80e has such a tall first gear?
Blakester is offline   Reply With Quote
Old 09-04-2017, 07:40 AM   #4
ticowarbird
BOHIC
Thank you. Didn't think about that.
Old 09-04-2017, 10:31 AM   #5
bct10985
Drives: 2010 2SS LS3, 2013 duramax
I wish i had of went with i higher stall than 3600. I can only manage a 1.6 60'. Went 10.4 first and only time at the track with the 4l80. It was shifting way early and ive since added more meth and more boost. Hoping to run a high 9 here soon
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 09-04-2017, 11:49 AM   #6
ticowarbird
BOHIC
I haven't chosen which stall to get yet. Everything else is has been decided so far. I'm waiting until after the holiday to talk to the shop that's doing it all. I also started looking at some things on nitrous express but doubt I'd pull the trigger.
Old 09-04-2017, 08:10 PM   #7
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I did the swap and was cutting low 1.5 60s. I was using a 3000 stall. mid 1.4s were in it with more converter. currently switching to glide so no further data for you
ttshovel is offline   Reply With Quote
Old 09-04-2017, 08:25 PM   #8
jrhagen
Banned
Drives: Camaro
I run consistent 1.44 60 ft with the 4L80e and ZL1 convertor. It's a little loose on the streets but I have gotten accustomed to it.
jrhagen is offline   Reply With Quote
Old 09-04-2017, 09:10 PM   #9
ttshovel
ttshovel's Avatar
6l80/90 converter in a 4l80e? I didn't know they shared the same input shaft
Old 09-05-2017, 01:07 PM   #10
jrhagen
Banned
Drives: Camaro
It's modified by RPM Transmissions. Stage 5 build.
Old 09-05-2017, 01:13 PM   #11
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
If you're looking for top drag strip times, auto is your way to go. Much easier to dial in, and much easier on the driveline. Definitely not as engaging or rewarding as rowing your own gears, just depends on what's most important to you.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 09-05-2017, 05:11 PM   #12
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
If you have allot of HP it should help you, I have had a 1.378 60ft with the 4L80. The first gear is the biggest difference.
MudderFinger is offline   Reply With Quote
Old 09-06-2017, 10:56 AM   #13
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Yeah I would just leave on more boost.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 09-07-2017, 11:32 AM   #14
ticowarbird
BOHIC
The more I read about it the more I see I will not regret the 4l80e. Will be done by November.
