Old 09-05-2017, 06:32 PM   #1
rbenotti
rbenotti's Avatar
Drives: '13 LS, '09 Forester, '11 HD SGlide
Vitesse throttle controller install - calibration question.
Bought one of these from someone on here (great transaction, and shipment).
I can only find he calibration instructions for the newer models with the dial. What is the correct procedure to calibrate one on a Gen 5? Don't want to mess this up.
Thanks in advance!!
2013 Chevrolet Camaro LS - M6
2011 Harley Davidson Street Glide
2009 Subaru Forester - M5
rbenotti is offline   Reply With Quote
Old 09-05-2017, 06:36 PM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
http://www.vitesse-motorsports.com/i...tall-guide.pdf
this is the one I used when I had mine
SSEssence is offline   Reply With Quote
Old 09-05-2017, 06:38 PM   #3
rbenotti
rbenotti's Avatar
Mine doesn't have the dial, and no on-off button. It doesn't do an L or H when I connect it.
Old 09-05-2017, 06:53 PM   #4
SSEssence
Instagram: Sangstah
those instructions have no mention of a dial, just a knob which is the button on the display, and when I did mine it showed a high and low so not sure what model you have.
Old 09-05-2017, 06:56 PM   #5
klswanky
klswanky's Avatar
Drives: 2013 Camaro 1LT RS
Thanks in advance!!
Here ya go.
Punisher Themed ; Magnaflow Resonated x-pipe / Muffler Delete ; Spectre Air Intake ; Red LED interior ; Smoked Tail Lights ; Silver bow-Ties ; DRL Harness
klswanky is offline   Reply With Quote
Old 09-05-2017, 07:52 PM   #6
rbenotti
rbenotti's Avatar
Originally Posted by klswanky View Post
Here ya go.
Thanks. I did this and on H it only went up to H2.1. I thought I read somewhere that it means it is already calibrated?
Old 09-05-2017, 10:39 PM   #7
Mike14bumblebee
Mike14bumblebee's Avatar
Drives: 2014 yellow 2SS/RS
Those are the instructions I went with and it worked fine.
K&N, Borla ATAK axle back, resonator delete, Speed Engineering headers,Vitesse, Zl1 wheels, ACS rocker panels, 1LE splitter
Mike14bumblebee is offline   Reply With Quote
Old 09-06-2017, 02:57 AM   #8
MrChrisLS3
Drives: 2018 1SS M6
Note that when you are holding the pedal down and push A, you might not see "100" right away, it may take a second or two. Just hold the button and keep the pedal pressed until you see "100".
MrChrisLS3 is offline   Reply With Quote
Old 09-08-2017, 03:04 PM   #9
rbenotti
rbenotti's Avatar
Thanks guys. Got it sorted out.
