Old 09-06-2017, 08:09 PM   #1
JWade
JWade's Avatar
Drives: 2014 Camaro SS/RS, L99
2014 RS/SS, LED in Halo out ... replacement bulb?
One of the LED bulbs, on one side of my passenger side Halo is out. Seems odd, I thought LEDs would be more or less "lifetime" of car.
Has anybody replaced this? Based on another thread, it looks like it may require opening (baking) the headlights and replacing a board, but wasn't sure since that thread was about something else.
Only 25K miles, possibly a warranty item?
2014 Camaro SS, L99
MBRP catback, CAI cai, Stainless Power LTs HFCs, tuned by KP Racing, Rohana RC7's, Z28 spoiler.
JWade is offline   Reply With Quote
Old 11-19-2017, 11:07 AM   #2
Brad956
Brad956's Avatar
Drives: 2014 Camaro RS
Did you figure out what bulb you needed and the process of changing it out
Brad956 is offline   Reply With Quote
Old 11-21-2017, 09:20 AM   #3
TORO1968
Drives: 2014 2SS 1LE
I have this same problem on my '14 2SS/RS 1LE. Curious if anyone has a fix other than replacing the headlight assembly...
TORO1968 is offline   Reply With Quote
Old 11-21-2017, 11:07 AM   #4
fussboss
fussboss's Avatar
Drives: 2014 2LT RS
I would really assume this is covered in the warranty..
fussboss is offline   Reply With Quote
Old 11-22-2017, 06:11 PM   #5
TORO1968
Unfortunately, my warranty was up in August. Any ideas from others?
Old 11-25-2017, 10:50 PM   #6
JWade
JWade's Avatar
No, unfortunately.
2014 Camaro SS, L99
Old 11-27-2017, 12:12 AM   #7
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Ask Gen5DIY, this is something they would probably know about
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 12-05-2017, 08:40 AM   #8
BruHop
BruHop's Avatar
Drives: 2014 2SS 1LE,RS,NPP,Recaros in SW
It does require baking the headlight in the oven to soften the sealant. Then pry the lens off of the housing. You have to buy more sealant to close back up after replacing the LED board.
BruHop is offline   Reply With Quote
Old 12-05-2017, 09:26 AM   #9
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
That's a bummer, how many miles on the car? If you're going to take apart the headlight might as well upgrade to one of those RGB color halos from Oracle.
SSEssence is offline   Reply With Quote
Old 12-12-2017, 08:27 AM   #10
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
You don't need to bake the headlight it can all be done from the rear with the cover removed.
