![]() Drives: Black SS, Black Expedition Join Date: Jul 2009
Where to Find Production Date?
Production Date used to be on the window sticker, now I am not sure where to find the production date of the car. Does anyone know where I can find the exact date of the production
? H |
Emerald Coast Camaros
Drives: 2010 Supercharged RJT SS! Join Date: Jun 2009
One place I know of, is under the hood.
You open up the hood then look in the engine comparment. There is a yellow sticker near the AC compressor.. The AC compressor is on the right side of the engine. You have to look real good though.. It will tell you the date and time it was built.
2010 Camaro SS LS3 Supercharged RJT!
Magnuson TVS 2300 Supercharger, ARH 1 7/8 LT Headers with 3" X-Pipe, Borla S-Type Axle-Back, DMH Low Profile Exhaust Cut-Outs, MTI Racing CAI, Stage 2 Camshaft(227/239 .614/.624) with new springs, Katech C5R Z Timing Chain, LS7 Bowtie Damper, MTI Hot Spark Plug Wires, MTI Racing Lowering Springs and Swaybars, Aluminum Oil Catch Can, 160 Degree Thermostat, MTI Tune. 554RWHP 528RWTQ Built By: MTI Racing Dyno Sheet here |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
The most accurate one found so far is on the rear differential. While this only shows when it was built and not the car, these are made specifically for your car the day before your car starts production. |
#4 | |
I forgot to mention that one that is on the rear differential.. it says the same date and time as the one under my hood..??
![]() Drives: 1969 Chevelle, 2010 1LT Join Date: Jun 2009
Your dealer should be able to give you the "GM Workbench" printout. The date of event code 3800 is the build date the way I understand it.
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation 2000: 8/15/09 - Accepted by GM. 2500: 8/18/09 - Preferenced. 3000: 8/18/09 - Accepted by Production Control. 3100: 9/9/09 - Available to Sequence. 3300: 9/9/09 - Scheduled for Production. 3400: 9/19/09 - Broadcast. 3800: 9/29/09 - Produced. ![]() 4000: 9/29/09 - Available to Ship. 4150: 9/29/09 - Original Invoice. 4200: 10/6/09 - Shipped. 5000: 10/13/09 - Delivered to Dealer. 6000: 10/13/09 - Delivered to Customer. |
#6 |
NCCOA Ch 1
Drives: 2010 Camaro 2SS/RS - Z4Z # 44 Join Date: Feb 2011
I you crawl under the back end, look just above the differential and you'll see a white tag about 3"x2". On the bottom will have the actual build date and time down to the second. Based on my info from GM Restorations, this is one of the final stickers to be placed on the car as it rolls off of the assembly line.
#7 |
TRI COUNTY TAMPA
Drives: 2011 1SS/RS VR/BLK A6 Join Date: Jan 2011
Look under the hood on passenger side down to suspension. You will see a barcoded label with a date and time. This is usually 1 day before your actual build date. My sticker reads December 1 2010. My cars actual build date is December 2 2010.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Sold: 2011 2SS/RS Join Date: Dec 2010
The door sticker is the official (legal) place for the production date, expressed in mm/yy. On some parts, it's misleading because the stamp is when that part was produced. Could have been sitting in a box for a month or two before it actually hopped into your car.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3/6M Litho#190 Join Date: May 2010
Have your dealer run you a build sheet,It will give you the build date.
If they won't do it PM me your VIN and email and I can run it.
![]() '11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned Proud Litho owner #190 - Homecoming Litho #120 '15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA |
#10 |
www.gkiser.com
Drives: 2010 2SS/RS, Auto, Summit White. R Join Date: Apr 2010
St Paddy Day
Roto-fab CAI, GMPP exhaust with tips, Pistol Grip shifter with paddle switches, 'Chevrolet' aluminum kick plates, Aluminum Bow Ties, ClearBra front bumper/facia + side views + gills + behind door handles. SS floormats. www.gkiser.com |
#11 |
www.gkiser.com
Check this thread. MS3Dale can give u build date and codes from ur VIN. That's how I found out my baby was born on St Paddy day last year.
http://www.camaro5.com/forums/showth...45#post2986045
#12 |
![]() Drives: 2010 2ss camaro Join Date: Oct 2010
ON MINE THERE IS A PRODUCTION STICKER ON THE PASSENGER SIDE FRAME RAIL JUST FORWARD OF THE AIR CONDITIONER COMPRESSOR. IT SHOWS WHEN THE FRONT SUB FRAME WAS ASSEMBLED 11-9-09. THIS MATCHES THE NUMBERS ON THE DIFF AND THE 3800 CODE DATE I GOT FROM THE DEALER..........
#13 |
Loves Big Block Power
Drives: 2016 Hyper Blue 2SS Join Date: Jul 2009
Thanks for the info guys!! Mine was born on 12-21-2009
David
2016 Hyper Blue 2SS Last edited by musclecarsfan; 03-28-2011 at 05:06 PM. |
#14 |
It's a monday built car
David
2016 Hyper Blue 2SS Last edited by musclecarsfan; 03-28-2011 at 05:07 PM. |
| 2011 Camaro Production Starts June 7. Last order date for 2010 model is April 10. | thegmconnection.com | 5th Gen Camaro SS LS LT General Discussions | 186 | 04-05-2010 04:17 PM |
| Age Gap - And -When to draw the line. | Asylum | Off-topic Discussions | 85 | 03-25-2010 10:54 AM |
| Convertible Camaro First Production Date? | Jake | Camaro Convertible Forum | 6 | 02-11-2010 12:07 PM |
| Production Stats and information | sherifdude | USA - Southcentral | 0 | 10-31-2009 03:07 PM |
| UPCOMING CAMARO IMPORTANT DATES | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 125 | 01-11-2009 12:31 AM |
