Old 09-14-2017, 07:31 PM   #1
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Another victim of the cheap a$$ slave cyl/ throw out bearing
Ordered an oem slave/ bearing...with the monster billet bearing support. And a Spec stage 2 clutch with thier steel flywheel... and the tick remote bleeder.
Already have the Wilwood remote resivour and tick ss line with the ideal garage master cyl....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 09-14-2017, 11:01 PM   #2
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Pic worth a 1,000 words How many miles ?
camguynj is offline   Reply With Quote
Old 09-15-2017, 06:39 AM   #3
Clarkstar
Clarkstar's Avatar
24k
Old 09-15-2017, 09:33 AM   #4
camguynj
camguynj's Avatar
Originally Posted by Clarkstar View Post
24k
Ut oh ...that's my mileage and yr
Old 09-15-2017, 10:15 AM   #5
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Good news is I've got a hard 36k on mine and it's fine. Here's hoping the best for yours as well!
But yeah, I'm planning on doing a full Monster setup in there once my clutch bites the dust. I can't believe how cheap GM went on this thing.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 09-15-2017, 12:29 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
2010 with 53k still living after some hard years. Want to do the the monster setup as well as the clutch an bleeder.
Orange Krush II
Old 09-19-2017, 09:22 AM   #7
shaggy2002
Drives: 2013 VR 2SS w RS 1LE
auto swap for the win. Going 4L80E
shaggy2002 is offline   Reply With Quote
Old 09-19-2017, 04:18 PM   #8
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Any warning signs or symptoms of this?
Old 09-19-2017, 07:12 PM   #9
Clarkstar
Clarkstar's Avatar
Pedal sticks to the floor....then it started grinding when I push in the clutch pedal...
Old 09-20-2017, 03:09 PM   #10
xc_SS/RS
Drives: 2010 Camaro SS/RS
Mine sticks, but it's just a little notchy through the shifter. I installed a return spring and no more sticking now. But even though the spring helped, the clutch action still feels like crap, and the point where it grabs is inconsistent. It's definitely a sign that it's gotta get changed either this year or next year.
Update this with your thoughts on the Spec clutch when it is installed. I'm interested in seeing what you think of it. Any reason why you chose that clutch over a twin disc?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 09-21-2017, 06:44 AM   #11
Clarkstar
Clarkstar's Avatar
I don't think the twin disc was necissary for 475-500 hp...I called spec... this is the clutch they recommended for my application.
Old 09-22-2017, 06:26 PM   #12
Clarkstar
Clarkstar's Avatar
Talking
Clutch is in... wow, what a difference. This baby grabs...but it's smooth too. It's like a brand new car. Before it chattered when taking off...that started when I installed the cam. Super happy with this clutch so far...
Wilwood resivour/ monster billet bearing support/ ideal garage master cylinder/ oem slave/ tick ss clutch line and remote bleeder line/ Spec stage 2 clutch and billet steel flywheel
Old 09-25-2017, 11:22 PM   #13
maroonponyina1LE
Drives: 2015 1LE
Hello Clarkstar and the other posters on this thread,
I have noticed that upon letting out the clutch in 1st gear/launch, and I think particularly with the Hill Assist active, I will get some kind of noticeable smell in the interior. Has anyone else experienced that, and knows what the source is?
Also, I have let some family members drive the Camaro, but without any recent clutch experience, some of the launches were not clutch friendly. I am expecting to have to replace parts at some point, but everything now still works. I don't have extensive mechanical knowledge. I thought the throw out bearing was not located anywhere near the slave cylinder - I thought it was located very close to the clutch itself?
Thanks in advance for your further replies!
maroonponyina1LE is offline   Reply With Quote
Old 09-27-2017, 06:48 PM   #14
maroonponyina1LE
Drives: 2015 1LE
Bump -
Seeking any responses to my questions above.
Thank you!
