Old 09-17-2017, 04:15 PM   #1
Onetyme
Onetyme's Avatar
Drives: 2011 LT Camaro
Parts identification confusion ?
So if one was going to gmparts and wanted to know which one is the radius rod, it doesn't list it. What's listed is the "front lower control arm" and the "rear lower control arm"
Which one/part is the so called radius rod in the front suspension?
Onetyme is offline   Reply With Quote
Old 09-18-2017, 06:43 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
The "front" one is the radius rod - the one with a bend in it - because the radius rod is located in front of the "lower control arm".
KillboyPowerhead is offline   Reply With Quote
Old 09-19-2017, 02:42 PM   #3
Onetyme
Onetyme's Avatar
the one with the bend in it
So would it be fair to assume that this picture is incorrect? There seems to be a lot of confusion on which part the radius rod is.
Old 09-19-2017, 04:42 PM   #4
BMR Tech
BMR Tech's Avatar
Drives: 2016 Camaro 2SS
Blue is the lower control arm, pink is the radius rod. GM refers to them as lower control arm rear(blue) and lower control arm front(pink).
Frank Steadman
Sales Tech
BMR Suspension
813-986-9302
BMR Tech is offline   Reply With Quote
Old 09-20-2017, 06:54 AM   #5
KillboyPowerhead
Drives: 2015 Z/22
Indeed; as BMR Tech inferred, that picture is wrong.
control arms, part number, parts, suspension help
