Old 09-17-2017, 09:47 PM   #1
Explit Player
IG @Brian_ _Self
Explit Player's Avatar
Drives: 2010 Camaro 2SS M6+17'Tesla Model S
ZL1 Cradle into SS
Going to be doing a swap to the ZL1 driveline and Ive been searching around for some info and came up unlucky.
1. Assuming I get a cradle with ZL1 Struts, will they mount up to my SS setup with no issue with no Magnetic Ride control or whatever all that pertains to?
2. Am I missing anything else?
  • Flange on my Trans needs to be swapped to the ZL1 driveshaft compatible one
  • ZL1 driveshaft
  • M6 ZL1 Cradle+probable struts
  • Diff Cooler plugs
  • Swap over brakes without any modification
  • Bolt the shit up and reprogram the speedo..
  • Be a happy camper once again, but with the added benefit of being able to track the car again
Explit Player is offline   Reply With Quote
Old 09-18-2017, 12:25 AM   #2
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
The driveshaft hardware should be replaced. Not sure about the mag ride struts. Id also suggest upgrading the cradle bushings to some polys.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 09-20-2017, 03:11 PM   #3
Explit Player
IG @Brian_ _Self
ZL1 Cradle into SS
Anybody know about the mag shocks?
Old 09-20-2017, 07:10 PM   #4
miller8907
miller8907's Avatar
Why not just use your SS struts. I dont think the ZL1 struts will be an upgrade if they work without mag ride.
Old 09-20-2017, 09:54 PM   #5
Explit Player
IG @Brian_ _Self
I would no question but they’re lowered an inch so there’s that... I would think the ZL1 spring rates and all that would be much better than my SS. But if it all fits I would be afraid that they are on a stupid setting that actually would hurt my performance. (No clue how mag ride works)
Old 09-21-2017, 03:52 PM   #6
miller8907
miller8907's Avatar
You could just swap springs. I think that gives an ss about .75 drop.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 09-21-2017, 04:19 PM   #7
Synner
Drives: cars
Magnetic ride isn't a bolt on, it's controlled by the computer. Hence the electrical plug on top for controlling the mag part of mag-ride.
Old 09-21-2017, 05:11 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Also the ZL1 spring are linear vs a variable on the SS or vice versa.
Orange Krush II
Old 09-21-2017, 09:21 PM   #9
ASimmons04
Drives: 2015 AGM 2SS RS 1LE
Why do you want to swap to a ZL1 cradle? You can upgrade the factory rear end and bushings to achieve any goals.
2015 AGM 1LE- Roto Fab intake, TSP Headers, BTR Stage 3 cam- 475 whp - SOLD
ASimmons04 is offline   Reply With Quote
Old 09-22-2017, 11:55 AM   #10
JusticePete
Drives: Camaro Justice
Mag ride without being connected to an OE computer is useless. The struts will do nothing but hold the spring in place. Sell them or toss them.
Old 09-24-2017, 08:00 PM   #11
rusn63@yahoo.com
Drives: 10 Camaro SS
I have a zl1 drivetrain and the only parts needed were a trans flange and all new bolts. The rear , halfshafts, and driveshaft all bolt in. You don't need a cradle. You will need to move the exhaust a little as the rear is larger.
rusn63@yahoo.com is offline   Reply With Quote
differential, differential swap, rear end, zl1 swap
