Old 09-19-2017, 04:21 PM   #1
SS376
SS376's Avatar
Drives: 2013 1SS LS3
Supercharger fix
I am considering a 2013 ZL1 but not sure if it might be affected by the supercharger issue. Anyone know if the issue was still present in 2013?
SS376 is offline   Reply With Quote
Old 09-19-2017, 04:46 PM   #2
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
Yes, but realize there is an extended repair for the supercharger only by GM. I think its 7 years 100,000 mi but you can google verify that. They don't repair it, they replace the whole unit. I don't know but I think all 5th gen's might have had that spring loaded supercharger coupling until it got the solid coupler installed by the owner or a GM replacement supercharger.
silversleeper is offline   Reply With Quote
Old 09-19-2017, 04:47 PM   #3
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Most of the 13's are. You need to have a dealer tell you if work was performed on the isolator.
JB'sZL1 is offline   Reply With Quote
Old 09-19-2017, 04:49 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Never had an issue with mine...
Extended warranty by GM is 10yrs or 100,000 miles free replacement.
Mods:
Old 09-19-2017, 08:49 PM   #5
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
The warranty on the supercharger is 10 yr or 120,000 miles. So don't let that bother you. If it rattles take to the dealer and have them replace the supercharger with the new design.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 09-19-2017, 09:28 PM   #6
SS376
SS376's Avatar
Thanks guys. I forgot about the warranty extension.
Old 09-20-2017, 12:55 PM   #7
jsd
jsd's Avatar
Drives: 2012 ZL 1 #370
I post again my question.
How i can be sure, then i receive the new design of the supercharger?
jsd is offline   Reply With Quote
Old 09-20-2017, 01:14 PM   #8
silversleeper
Big Crow
Drives: '13 ZL1
I do not know.
If a dealer did replace it then it should be in their computer database. I don't know if there were any markings or serial numbers on the replacement supercharger to externally verify them. Taking the belt off and twisting the pulley back and forth might reveal excess slack or noise but I wouldn't count on that. Even the solid replacement couplers appear to have a small amount of slack in them. Listening to it if has already started going bad is a rattle noise that sounds like marbles in a can rolling around.
It is lots of work to take off the supercharger to see if it has been done or not. So I can not answer your question, sorry
Old 09-20-2017, 01:18 PM   #9
JB'sZL1
Wow.
Old 09-20-2017, 03:06 PM   #10
jsd
jsd's Avatar
thanks for the answer
but i am in a little bit other situation, the you guys. I have the order one piece from the usa, to make the change here in switzerland. i have to pay it myself and this is the reason, i will be sure, then i buy the new design
i don't have dealers around here, which can tell me, if this work was performed on the isolator.
And how i know from this forum, the redesign has not just an other isolator, it have also an seal.
Sorry guys, for my english, but its not my first language
Old 09-20-2017, 04:28 PM   #11
JB'sZL1
There are 6 bolts holding the snout on. There is the isolator. You can see for yourself upon delivery if you're mechanically inclined.
To reiterate: All you have to do (short of confirmation from the dealer) is confirm with the vendor that the isolator is not the of the original spring type.
I cannot state it any more plainly. If the vendor cannot assure you the original isolator has not been replaced, and it is beyond your scope to replace the isolator yourself, find another vendor. I stated this plainly in the thread you started.
You have been talking about isolator replacement for over a year now on this forum.
I don't think English is your problem.
Old 09-20-2017, 09:50 PM   #12
jsd
jsd's Avatar
Its good, you know my problems. But i think you dont understand what i mean and this since more then one year. Because nobody can give me an answer for my question.
I dont want receive an old design. This is my problem. And i dont want change the isolator on a new piece which come from the vendor.
I understand your purposes jb since one year. You posted your answers also since one year, but you to, you never give an answer, which helped me know i order the redesigned supercharger or not
I know my self what i can do and what i cant do.
Old 09-20-2017, 10:26 PM   #13
JB'sZL1
Then just purchase a new supercharger. Eaton, Whipple, Magnusson, and a couple of others. Take your pick.
Old 09-20-2017, 11:54 PM   #14
Quicklsa
Quicklsa's Avatar
Drives: 15zl1 m6 with recaros
It's the same one I-dent-ical with no cosmetic differences either the only difference is a bushing coupler(isolator) that connects the blower to the pulley shaft (on the drive shaft from the blower to the pulley) one has a spring and one is solid. Since it's a 13, factory it came with a spring loaded so take off the belt with a 1/2" breaker bar or wrachet wrench and twist the pulley back and forth rapidly a few times and you will notice the difference one is solid one has play. Then you know what you have Easy peezy
2015 zl1 rotofab,pnpblower,2.35,e85,2"headers catless. 650(93)700(E85)
Quicklsa is offline   Reply With Quote
