09-28-2017, 10:23 AM | #1 |
Go Cougs!
C6 ZR1 CCW's on a ZL1?
Just had a buddy with a C6 ZR1 post he might be selling his CCW's off his car (he drag races). I have found the limits of the ZL'1 brakes and need an upgrade. My question is will the C6ZR1's CCW's work and our 5th gen ZL1's?
09-28-2017, 10:25 AM | #2 |
Instagram: Sangstah
I dont think the offsets are compatible but I may be wrong.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
09-28-2017, 05:04 PM | #3 |
Drives: Fast Join Date: Mar 2015
You're talking about the Carbon Ceramic brakes?
No idea if they would bolt on or not, however I doubt it'll be worth it. |
09-28-2017, 06:40 PM | #4 |
Go Cougs!
09-28-2017, 08:54 PM | #5 |
Drives: 2013 ZL1 Convertible/2015 Z/28 Join Date: Mar 2013
2014-15 Z/28 Carbon Ceramic Brakes:
Rotor diameter (in / mm): front: 15.5 / 394 x 36mm wide rear: 15 / 390 x 32mm wide 2009-13 C6 ZR! Carbon Ceramic Brake: Rotor diameter (in / mm): front: 15.5 / 394 rear: 15 / 380 Rear rotors are a different size. Hats may have different specs beween Camaro and Corvette. Calipers may be different as far as mounting tabs and bolt specs. What year ZR1? How many miles on the brakes? Mass of the rotors compared to minimum mass? May be better trying to go with Z/28 CCBs. Believe the front is direct bolt on but not sure if any difference to the rear knuckles from ZL1 to Z/28 as they appear to have different part numbers. Hope this helps. |
09-28-2017, 10:47 PM | #6 | |
Go Cougs!
