Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 10-02-2017, 08:08 AM   #1
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
Did some garage floor epoxy. Came out nice!
I learned a lot along the way. Feel free to hit me up with any questions you may have. Our garage is 49'x24' separated into 2 sections. One section is about 12'x24' and the bigger section is 36'24'. We don't do any heavy work in the big section, we just mainly use it to store cars. The plan is to make it look like a showroom, put up a small table, chairs, TV and fridge.
One of the pads was in rough shape with some deeper cracks. I'm not about to shell out $4k to have new concrete poured so I just smoothed it out the best I could.
I originally used a concrete resurfacer. It said you could apply it 1/16th of an inch to smooth out any pits or cracks. What a joke this crap was. Went on great, but when it dried it was weak as hell. I could scuff my foot and it would disintegrate. I ended up removing about 90% of it. I then put a concrete primer down and allowed it to dry.
The epoxy I used was Rust-O-Leum Epoxyshield. I used the 2.5 car kit. If you buy it at Lowe's or Home Depot they can mix it into a variety of colors. I chose Teal Green.
Here's the first section going down, with some flakes added:
The directions say to do apply it in small sections. After looking at the results I should have applied it to bigger sections to get the color more uniform. You can see some lines in the epoxy. It's hardly noticeable now with the clear on.
After the epoxy dried (2 days) I ended up putting 3 gallons of clear on ($93). I put the first gallon on with a roller. I used 1 gallon for both pads. I didn't like the finish it had from the roller. It had an orange peel look. So I bought 2 more gallons, but this time I used a squeegie. Here's the result:
A week later we did the other 2 pads in the main section, and then used 1 gallon of clear and squeegied it on. After 4 days we parked some of the cars in there. I put pads under the wheels just to be safe for now. The results were amazing:
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 10-02-2017, 09:21 AM   #2
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
looks great
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 10-02-2017, 09:44 AM   #3
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Really nice job, looks good.
How did you keep the clear from filling up the relief cuts in the floor?
HOJO is offline   Reply With Quote
Old 10-02-2017, 01:35 PM   #4
swampcritter
Drives: 2014 Camaro LS / 13 zl1
That floor looks amazing , that IROC is beautiful also
swampcritter is offline   Reply With Quote
Old 10-02-2017, 03:23 PM   #5
joelster
joelster's Avatar
Some of the clear ran into the expansion joints, but not enough to concern me. The clear is not very thick. A gallon doesn't really cover a lot of sq/ft.
The IROC is my gf's. We're looking into getting another one soon!
1979 Y84 Trans Am
1986 IROC-Z
Old 10-02-2017, 07:56 PM   #6
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Looks like it turned out great. Nice job!
witenite is offline   Reply With Quote
Old 10-03-2017, 10:51 AM   #7
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Nice job! What was you total cost per sf. Minus the mishap with the skim coat of cement layer? I have a large 2.5 bay I been leaning on doing the floor in epoxy. Also how long was the cure time for putting the garage back to use?
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 10-03-2017, 02:01 PM   #8
hkittrell
hkittrell's Avatar
Drives: 2015 Camaro 1SS/RS 1LE
I had that same IROC back in the late eighties.
hkittrell is offline   Reply With Quote
Old 10-03-2017, 05:05 PM   #9
joelster
joelster's Avatar
The epoxy kits were $109 each. I used 3 gallons of clear on the first 2 pads and 1 gallon of clear on the 2nd set of pads. Each gallon was $31, so $124 in clear. Add in brushes, pans and a squeegie. I spent a total of around $400ish for the whole project, roughly 36'x24' with some cabinets that stick out eating up some sq/ft. So it's really about 450-500sq/ft that I applied the epoxy to. $1.25 per sq/ft, roughly.
Cure time says 24 hours and you can walk on it. I really didn't want to push it. I let it cure for 3 days before I went into the area and walked on it. No sense in rushing it, when you've gone that far. I still have pads under the tires of the cars just to be safe.
Oh, just to be clear, I did NOT add the anti-slip additive that you can buy. The floor is very slippery when it's wet. If you plan on working on an epoxy coated floor, I would get the anti-slip additive.
1979 Y84 Trans Am
1986 IROC-Z
Old 10-04-2017, 03:18 PM   #10
Jayjellyfish212
Drives: 2014 1LE
Cool and thanks for the info. Is the anti slip additive more like a light sand type texture? I can see if wet could be a bit slick with high gloss clear. Curious if it just adds a light sand texture. Cost seems reasonable too. I was leaning to do a plain light gray or light beige so I get good light reflection and brightness. I think I'd be doing up to my cabinets and tool boxes only . It would be a nightmare to move them all.. lol. I'd probably be looking at a floor surface area of 24w x 18d mainly where cars are parked only. What clear did you use?
Old 10-05-2017, 06:08 PM   #11
joelster
joelster's Avatar
The clear was called SEAL-CRETE or something like that. It was right next to the Rust-O-Leum stuff on the shelf.
1979 Y84 Trans Am
1986 IROC-Z
Old 10-06-2017, 03:16 PM   #12
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Gonna be doing this to my garage I want a black floor in my garage.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 02-05-2025, 03:42 PM   #13
tilstad
Drives: 2011 SS / RS Convertible
Nice third gen! Great results on the floors. My 2 cents is to go with light gray color and skip the chips as it's much easier to find a screw that fell down on a monotone colored floor.
tilstad is offline   Reply With Quote
Old 02-05-2025, 08:18 PM   #14
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
Great job. I need to do this to mine as well. Currently it looks like a 10 year old placed the concrete.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
