Old 10-02-2017, 06:54 PM   #1
ARrado15
Drives: 2011 Camaro 2SS
Worlds Toughest Dirt
Hey all,
So I'm having issues removing this dirt from my paint. I took a trip across country a month ago, and got some dirt/mud/clay on the rear portion of the car, and on the entire rear bumper. I have never seen something so hard to remove from paint before. I have tried washing the vehicle, Goo Gone, degreaser, bug and tar remover, and even a clay bar, and cannot get anything off. The only success I have had was using the goo gone on one tiny spot, and rubbing it for over 15 minutes to get the dirt off. Can anybody recommend any sort of treatment to get this dirt off? It looks absolutely terrible on the car and i'm so sick of looking at it.
2011 Camaro SS - Kooks 1 7/8" LTH - Kooks HFC - Solo Mach XL Catback - CAI Intake - VMAX TB - Howards ASA Cam
ARrado15 is offline   Reply With Quote
Old 10-02-2017, 07:19 PM   #2
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
Have u tried wd-40?. Spray it on, and use your fingernail to remove it. Works for me everytime
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 10-02-2017, 07:28 PM   #3
ARrado15
WD-40 is the last thing that i've read that I have not tried. Reason I haven't tried it, Is I can't even get the dirt off with my finger nail, and figured the WD-40 wouldn't work. Ill definitely try it though. Any other ideas if this doesn't work?
Old 10-03-2017, 05:21 AM   #4
BRZN
BRZN's Avatar
Drives: 2012 1LT
A picture might help.
Try Adam's Wheel Cleaner mixed 50/50 with water. Have the vehicle in the shade and cool to the touch, rinse the car down, liberally spray the affected area with the diluted Wheel Cleaner and let it dwell on the paint for a few minutes. Don't let the product dry on the paint; mist it with more to keep it moist if it starts to dry. After a few minutes rinse it off and then wash the area as usual. If some still remains, claying may remove the rest at this point as it should have softened what's there.
If the above doesn't work there are Industrial Fall Out Removers available, and also more aggressive clay bars out there that'll do a much better job than the consumer grade clays found at most auto parts stores. After the more aggressive claying polishing is usually required.
BRZN is offline   Reply With Quote
Old 10-06-2017, 06:46 PM   #5
ARrado15
Sorry for the delay in picture, but here it is. It looks like the type of dirt you can just pick off with your fingernail, but I just can't get it off. It looks like this on the entire back end of the car, as well as the rear half of the sides...
Old 10-06-2017, 07:04 PM   #6
Synner
Drives: cars
Looks like rock chips from a lawn mower.
Old 10-06-2017, 07:05 PM   #7
swampcritter
Drives: 2014 Camaro LS / 13 zl1
Go to www.Cleanoff.com and see if that will work
swampcritter is offline   Reply With Quote
Old 10-06-2017, 08:09 PM   #8
ARrado15
It's definitely some type of dirt. I was able to get individual dots off with goo b gone but nothing more.
Old 10-08-2017, 06:05 AM   #9
BRZN
BRZN's Avatar
Drives: 2012 1LT
Almost looks like road line paint.
If so, 3M Adhesive Remover and a Plastic Razor Blade will scrape the pieces off. Polishing afterwards would be recommended.
Old 11-05-2017, 08:40 PM   #10
ARrado15
Okay, so for anybody wondering, I was able to get the dirt/paint/clay off the paint. I used mothers clay bar, and clay bar'd the rear end for 9.5 hours. Now just need to do the side of the car...
Old 11-05-2017, 08:43 PM   #11
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Get a magic eraser from walmart... cheap, and it works wonders!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 11-05-2017, 08:46 PM   #12
Clarkstar
Clarkstar's Avatar
Use warm water and some car wash soap...
Old 11-06-2017, 08:45 AM   #13
BAD DAB
BAD DAB's Avatar
Could it have been cement or paint from road crews painting lines? I've never heard of any dirt that would do that.
Old 11-15-2017, 04:56 PM   #14
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Did you try extra elbow grease like this? Lol
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
