Old 10-02-2017, 08:01 PM   #1
hussain112ali
hussain112ali's Avatar
Drives: Camaro V6 2LT RS 2012
Send a message via Skype™ to hussain112ali
Exclamation Last hope before open the engine ! PCV ?!!
Hi guys ...
I'm facing a problem with my 2012 2LT Camaro ...
My car is losing oil ... and after hours of searching I find out a huge amount of oil on the end of the air cleaner hose !!!
so I searched and most what I found was about the PCV ...
so my question is that ... does the part that marked with red in the attached pictures below the PCV and if it's the PCV how can I change it because I tried to remove it but it's didn't move a bit ?!!
PLZ help because I'm running out of options and I don't what to open the engine
hussain112ali is offline   Reply With Quote
Old 10-02-2017, 09:24 PM   #2
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
That's the PVC. It doesn't need to be changed . It doesn't have a ball in it like the old days . The LFX engines do tend to burn a bit of oil depending on how hard you drive them.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 10-03-2017, 03:12 AM   #3
hussain112ali
But dear ... mine is losing a lot of oil !!! around 2-3 Liter per 400 KM on highways ... I don't thank that's normal ... so now I think I have a bigger problem with my engine
Old 10-03-2017, 12:22 PM   #4
1Coopgt
1Coopgt's Avatar
Unless you are a female don't call me Dear .
I'm not sure what to tell you. Have you done a compression and leak down tests on the cylinders . I go through about 1.5 quarts of oil every 5 thousand miles.
Old 10-03-2017, 10:43 PM   #5
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
I seem to recall reading up here situations where people's catch cans were filling up at an abnormally fast rate. I don't remember what the cause was, but it was something weird on the inside of the valve cover which was causing oil to be sprayed right into the PCV line. I believe it was a minor fix, but don't recall what the problem was at all.
Jazzzed is offline   Reply With Quote
Old 10-04-2017, 01:51 PM   #6
gringo
gringo's Avatar
Drives: Camaro V6
I think it was called the orfice tube mod fix. That little hole in the tube that sticks out from the valve cover needs to be drilled out larger.
gringo is offline   Reply With Quote
Old 10-11-2017, 06:27 PM   #7
hussain112ali
after I spent hours on internet (Camaro and other cars forums) ...
all of them told me that's the issue is a PCV issue
but it's confirmed that it's a piston issue
After we open the engine we find-out 3 broken pistons
so we changed them and changed the rings and now it's working well
Old 10-11-2017, 09:55 PM   #8
1Coopgt
1Coopgt's Avatar
Good to hear . But damn that sucks . Any pics?
Old 10-12-2017, 07:28 PM   #9
gringo
gringo's Avatar
Drives: Camaro V6
So, the block was reusable? No scoring on the cylinder walls due to the broken pistons?
Old 10-16-2017, 05:03 AM   #10
hussain112ali
Yup it's sucks and cost me 1400$
Old 10-16-2017, 05:05 AM   #11
hussain112ali
The block cylinder walls is 100% ok ... so only pistons and rings changed
Old 10-16-2017, 10:08 AM   #12
1Coopgt
1Coopgt's Avatar
Wow that must have been making some funky noises besides burning a lot of oil . I've never seen pistons break like that .
Old 10-16-2017, 06:01 PM   #13
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Wow!
Using way too low octane gas?
Rock-It Man is offline   Reply With Quote
Old 10-16-2017, 06:47 PM   #14
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
Hit the Rev limiter one too many times?
HyperV117 is offline   Reply With Quote
