Old 10-04-2017, 01:13 AM   #1
lkaire75
Drives: 2014 Camaro V6 2LT
Help! 3.45 LSD conversion from a 2LT Auto, very confused with parts
Hi, i have a 2014 camaro 2lt automatic, i want to convert the differential to a 3.45 LSD from an SS, i know i need the 3.45 diff from a manual car and the driveshaft from an SS auto, my confussion is with the axles, do i need the auto axles or the manual axles?, and i think the hubs from an SS are the same from auto and manual.
Can somebody help me?, if you can tell me also the part numbers would be great. Thank you!
lkaire75 is offline   Reply With Quote
Old 10-04-2017, 09:20 AM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
axles are the same...hubs are good to go too..depending on the age of the diff you may want to replace the axles seals too...good luck!
Old 10-04-2017, 10:20 AM   #3
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
You will need the SS diff, the rear portion of the SS dive shaft, both SS axles (or if a Manual V6 they are the same) and the hubs (same thing, but always best to by these new). New seals in the diff are also inexpensive and a good idea as noted above.
Elite Engineering is offline   Reply With Quote
Old 10-04-2017, 10:51 AM   #4
lkaire75
You are very helpful, Thank you!
lsd conversion
