Old 10-04-2017, 09:51 AM   #1
thebluecamaross
thebluecamaross's Avatar
Drives: 2010 Camaro 2SS/RS ABM
Whining noise upon acceleration?
I hear this whining noise (like a faint supercharger noise) when the A/C is on.
Intensity increases as the RPMS increase.
Could this be the belt?
The A/C blows cold air.
thebluecamaross is offline   Reply With Quote
Old 10-04-2017, 11:02 AM   #2
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Some people complain about the blower motor whining. My car does it. See if the sound depends on fan speed
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 10-04-2017, 12:29 PM   #3
Gasoholic
Drives: o
Doesn't really sound like a belt problem the way you described it. But could be wrong. Easy enough to replace the belt. Well, sort of easy. It's a stretch fit so if you've never swapped one before it might not seem so easy. They make a special tool for it.
My truck has a noise from the A/C that I first thought it was coming from the trans. It only does it in 1st and 2nd. Sort of groans right before it shifts.
I figured out it was actually coming from the A/C compressor and not the trans. Its weird. But I figure as long as it works I'll keep driving it. A/C season is almost over anyway.
Gasoholic is offline   Reply With Quote
Old 10-04-2017, 12:33 PM   #4
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
But.. you will need the AC for defogging your windows in those cold MI winters!
DvKillar is offline   Reply With Quote
air, camaro, camaro5, conditioning
