10-09-2017, 11:49 AM | #1 |
Drives: 2015 Black Z28 Join Date: Oct 2017
What type of tires?
What type brand and size replacement tire are guys going with. 305/30-19 is stock, what about 305/35-19 replacement? (Its just a 1/2" taller) I may track it, but only every once in a while, mostly will be street driven.
10-09-2017, 12:46 PM | #2 |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
That is a huge question and there are probably 50 threads already on it.
50/50 toss up on keeping 305 vs going up to 325. I have not heard of anyone going taller. I will not be going taller, not a chance. I want the car lower.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
10-09-2017, 05:34 PM | #3 |
Drives: 15 z28 white Join Date: Apr 2016
Bridgestone Potenza RE11s 325/30/19 on all 4 corners of my car for the last year. They fit perfectly with no rubbing issues. Lots of guys running them on this forum and they are half the price of Trofeos. They ride much better in the street without the "tramming" issues the Pirellis have. The height looks exactly the same to me when compared off the car. There not for the track though.
10-09-2017, 06:10 PM | #4 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
RE11s here. 305 front and 325 rear. Great tire.
10-10-2017, 09:17 AM | #5 |
Actually, they are a very good track tire. I am getting two sets this year and 1 set of R7's. I will do most HPDE's on the RE11's because they last so much longer then Trofeo's and hold the track very well. Yes they are slower but not that much slower.
I see a lot of BMW guys on them and several Porsche guys. They are a well respected tire for those looking to save a little money.
10-10-2017, 11:23 AM | #6 |
Drives: 2018 ZLE Join Date: Jul 2014
Michelin Pilot SS.....305 front, 325 rear......love them!
10-10-2017, 06:20 PM | #7 |
Drives: Black 2015 Z28 #457 Join Date: Sep 2016
For street driving the MPSS was my choice. Maybe the new MP4S which Ive read is an improvement. I run 325/30/19s on all 4 corners. Just keep in mind the trofeo stock tires are wider than most of the 305s, so the tires will 'look' a bit stretched. my 325/30s only look slightly wider in the fronts because of the narrower wheel but in the back are comparable to the trofeos square look.
12-18-2017, 06:43 PM | #8 |
Drives: '15 Z/28 #698(A/C,AW) & other stuff Join Date: Oct 2017
Most recent somewhat related thread I could dig up without starting yet another tire thread question...
Looking to replace original Trofeo's with a 3 season street tire. Track manners are not a huge consideration for these tires/rims. I mainly want the tires to perform well in questionable Colorado weather that I might not start in but will inevitably encounter on the way home (rain, possibly snow, cold temps). Car will be used as a "drive it when possible" car. Not necessarily looking to go bigger on these tires than stock. So far it looks like the Bridgestone Potenza's and the Michelin PSS might have some votes, anyone else want to chime in on your likes/dislikes for 3 season-ish tires?? Bonus questions - what is the realistic safe pavement temperature for driving on the Trofeo's?? I've heard things get a bit dicey below 40..?? What happens then - does the tire come apart before my nerves/ability, or vice versa?? Thanks, Mike |
12-18-2017, 06:50 PM | #9 | |
Drives: 2015 Z/28, 2007 HHR Join Date: Jan 2014
12-18-2017, 07:51 PM | #10 |
Michelin pilot sport tires are notorious for cracking in cold weather I’ve seen it frequently and always seems to be due to winter temps on these tires.
12-30-2017, 05:00 PM | #11 |
Drives: 2015 Z/28 Join Date: Nov 2013
I went 285/35-20 MPSS on Forgestar rims. The diameter of the tire is 2" greater than stock. Much better street manners and raises the car 1" for better curb clearance. Narrower width eliminated tramlining. Square setup allows rotating tires.
Sent from my XT1650 using Tapatalk
2015 Z/28
2020 Taycan 4S 2006 911 C4S Cab 2009 911 Turbo Cab |
12-30-2017, 06:46 PM | #12 | |
12-30-2017, 10:21 PM | #13 |
2015 Z/28
01-01-2018, 12:58 PM | #14 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
Pretty much all tire combinations are in here:
http://www.camaro5.com/forums/showthread.php?t=438314
🔺22 RS E TRON GT
🔺21 Model S Plaid |
