Old 11-07-2009, 03:03 AM   #1
tommygun6644
tommygun6644's Avatar
Drives: 2010 Camaro 2SS/RS & 2006 Cobalt LT
Question about storing for the winter (my situation)
Hey guys, here comes the dreaded time were she must go away for the winter
Questions!
This is the first car I've ever stored.
I have a one car, unheated, garage.
Currently no car cover for it.
I live in NY. We have some cold winters.
Suggestions? Should I get a cover? What should I do about the tires, ect?
Thanks in advance.
tommygun6644 is offline   Reply With Quote
Old 11-07-2009, 07:08 AM   #2
cschmidt1956
cschmidt1956's Avatar
Drives: Too Little time to drive....
I have stored cars in unheated garages with good success. The most important thing to do is prevent the moisture from the ground coming up under the car. This can be done by putting some sort of barrier under the car. I use multiple runners that you see in the entryways of some stores. They are a THICK vinal material with like a tight heavy duty carpet on them. You can also buy garage mats like at Sam's Clubs or BJ's Wholesale Clubs that will give you the coverage you need.
Car Covers are nice, but expensive. My garage has too much wind go through it when the door is open so I don't use one.
I wax the car before I put it away and then use a California Duster to get the dust off. With the price of these at most Target stores being $10 or $11 dollars, I use them till they start showing signs of dirt and then replace them. The new ones clean my cars and then the older ones get used on the lawn equipment and other gear.
I tend to start the car and move it in and out of the garage on nice dry days. I only drive it on the roads when it has rained HARD and washed most of the salt away, and then dried.
Hope this helps...
Chris
cschmidt1956 is offline   Reply With Quote
Old 11-07-2009, 04:51 PM   #3
tommygun6644
Thanks
Old 11-08-2009, 10:25 AM   #4
kmthor00
Drives: 2013 ZL1 Black
I top off the tank, pump a little extra psi in the tires, maybe 36 psi & always hook up a battery tender. Have done this for years with my vettes & all is good come spring time.
kmthor00 is offline   Reply With Quote
Old 11-08-2009, 01:05 PM   #5
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
Put Sta-Bil in the gas .
zen is offline   Reply With Quote
Storing for the winter? blkdymd USA - New England 45 12-31-2014 07:47 PM
Winter Storage mbauer14085RS/SS2010 5th Gen Camaro SS LS LT General Discussions 76 10-05-2009 11:48 PM
Winter tires - Quick question about rims CamK18 Wheels and Tires Talk Sponsored by The Tire Rack 1 10-04-2009 01:00 AM
Storing for Winter questions joepitt Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 10 09-29-2009 02:04 PM
