Old 10-12-2017, 11:17 AM   #1
LitosZX
LitosZX's Avatar
Drives: '10 2SS/RS Cyber Gray
Exclamation '10 SS FPCM with 1LE FPCM
Good morning
My fuel pressure control module has gone bad
- cause unknown
I found another member selling his 1LE fpcm, my question is will the 1LE fpcm work with my SS fuel pump??
any and all input is appreciated.
M6, 376ci, LS3 Top End, Holley High Ram, A little compression.
LitosZX is offline   Reply With Quote
Old 10-12-2017, 09:14 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
My understanding is the 1LE has a ZL1 fuel pump but only a SS Fuel pump control module.
Orange Krush II
Old 10-14-2017, 04:34 PM   #3
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Whatever the case, your pump would work with either one. The pump only cares about seeing a DC voltage.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
1le, camaro ss, fpcm, fuel pump, zl1
