Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Great Lakes > Local Marketplace
Old 10-16-2017, 10:44 AM   #1
Fab4Fun
Drives: 2014 Camaro 1SS/RS/1LE 6M NPP
FS: 1LE wheel bearings, new in box
Bought these from the dealer but never installed them:
Fronts: part number 23103115
Rears: part number 23103121
$300 for the whole set
Fab4Fun is offline   Reply With Quote
Old 02-11-2020, 01:52 PM   #2
shu92870
shu92870's Avatar
Drives: 2014 Camaro SS 1LE
Bearins
I know old but do you still have these bearings?
ARE they the 1LE/ZL1 specific bearings?
Im seeing a bunch of different comments.
shu92870 is offline   Reply With Quote
Old 02-11-2020, 02:03 PM   #3
gtstorey
There was pretty wide consensus on here that these were the same;
https://www.ebay.com/itm/Chevrolet-C...IAAOSw32lYvxxl
Old 02-11-2020, 02:16 PM   #4
shu92870
shu92870's Avatar
Saw those in my ebay search.
Can those really be right price?
That's crazy cheap.
Too good to be true?
I contacted seller to see if they know for sure.
Old 02-11-2020, 02:19 PM   #5
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Yeah I was going to say there is no difference between SS and 1LE wheel hubs
SSEssence is offline   Reply With Quote
Old 02-11-2020, 02:35 PM   #6
shu92870
shu92870's Avatar
Actually i thought there is?
SS have different splines compared to the 1LE?
Thats what ive read?
ZL1/1LE have bieffier axles? Hence the different splines and parts?
Old 02-11-2020, 07:13 PM   #7
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
There's no difference. I used my SS hubs with ZL1 axles when I did my ZL1 rear end conversion. Same exact thing, I even bought a set of ZL1 hubs thinking I would need to swap them out and didn't have to. I took off one of my SS hubs and they were the exact same as my SS hubs.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 07-22-2021, 07:39 PM   #8
Fab4Fun
Bump.. moving, so don't want to bring these with me again. Best bet is to email me. Ben.B <at> Flinktech.com
Old 07-22-2021, 07:41 PM   #9
Fab4Fun
Oh, and there was no fitment difference, but the bearing/internal grease spec is different for 1LE. Aftermarket/ebay will just sell whatever fits.
Old 07-23-2021, 04:00 AM   #10
AlanRubin
Banned
Drives: 2010 LS
SS, 1LE, ZL1, Manual V6 all have the larger diameter center hole for the axles, for the
REAR. Can use ANY up front, on any car, there is no axle. Manual wheel bearings are
cheaper than AUTO wheel bearings, so I run those up front.
Difference is supposed to be the internals, and lubrication for the 1LE and ZL1.
These are all orbitally formed bearings, there is no preload, you bolt on and go.
Vipers use a dummy axle, like a spindle, for up front so the wheel doesn't fly off if the
bearing fails.
AlanRubin is offline   Reply With Quote
