Old 10-16-2017, 03:17 PM   #1
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
JDP Camaro 9.90 @ 145.16
We've been chipping away at our set up and we got it into the 9's this past weekend. We need to get our 60ft down but we should see mid to low 9's next season with some additional changes. We run at 4500 FT here in Utah also.
This car is full weight at 4400LBS with driver. We're running a 429ci LSx with an F-1X ProCharger, JDP Centri Camshaft Package w/6-Bolt Heads, Squash Fuel System w/ID-1000 Injectors, Alky Control Meth System, KOOKS 1-7/8" LT's (Going 2") and 3" KOOKS Quad Tip cat-back, 4L85 Trans w/YANK 4000 Converter, Ridetech Triples w/JDP 15" Conversion and more.
Kind regards,
Jordan Priestley
801-545-4215
JDP Motorsports is offline   Reply With Quote
Old 10-16-2017, 04:53 PM   #2
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
Good god Almighty! Congrats!
graf101 is offline   Reply With Quote
Old 10-16-2017, 05:08 PM   #3
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Nice. This is where i want to be with mine. What rear gear?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 10-16-2017, 05:13 PM   #4
Bo White
Bo White's Avatar
Yeah theres 2 tenths easily just in the 60ft.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 10-16-2017, 08:46 PM   #5
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
That's bad a$$ fo sho!
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-16-2017, 10:21 PM   #6
GR8WHITE1
GR8WHITE1's Avatar
Drives: camaro
Nice! What has been done to the diff/axles to keep it alive?
GR8WHITE1 is offline   Reply With Quote
Old 10-17-2017, 06:41 AM   #7
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
Way to go JDP!!!
Old 10-17-2017, 07:11 AM   #8
jrhagen
Banned
Drives: Camaro
I just ran, in the 1/8, last weekend: 1.41, 4.12, 6.44 at 106.5.
Any guesses what it would do in the 1/4?
jrhagen is offline   Reply With Quote
Old 10-17-2017, 07:44 AM   #9
JDP Motorsports
Thank you!
We've got the ZL1 M6 rear differential with a 3.73 gear.
We should see 2-4 tenths pretty easy once we get into the 1.3-1.4 range. We typically see .1 in the 60 translating into .2 on the big end.
Appreciated!
We've got a ZL1 rear end conversion with a 3.8" DSS carbon driveshaft.
Originally Posted by hrpiii View Post
Way to go JDP!!!
It depends on your combination. Our car moves on the top end and we were 6.48 at 113.75 in the 1/8. You should be in the low 10's I would guess.
Kind regards,
Jordan Priestley
801-545-4215
Old 10-17-2017, 07:46 AM   #10
jrhagen
Banned
Drives: Camaro
Yeah, I figured. You were pulling on me pretty good by the end of the 1/8.
I would be happy with low 10s.
Old 10-17-2017, 08:59 AM   #11
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
similar to my setup. 427/f1x
so far my best is 9.2@155mph and that was leaving from idle with 0 boost. So there is def a ton left in your setup. congrats on hitting the 9s.
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 10-17-2017, 09:05 AM   #12
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
sweet, congrats on the time!!
SSEssence is offline   Reply With Quote
Old 10-18-2017, 08:06 AM   #13
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Congrats. What boost you running.
1fast is offline   Reply With Quote
Old 10-18-2017, 08:22 AM   #14
JDP Motorsports
We'll get it dialed in and refined. Solid numbers yourself!
We appreciate it!
We're running 18psi currently and it made 1032 WHP and 830 WTQ through the 4L85 trans.
Kind regards,
Jordan Priestley
801-545-4215
5th gen, camaro, drag race, jdp built, jdp motorsports
