Old 10-17-2017, 04:53 PM   #1
Bicyclemaster400
Drives: 2014 1LT RS Camaro
Strange Noise Around 3500 RPM
Hi All,
First post here. I have a 2014 1LT RS Camaro. Love it.
Lately it has been making a strange noise around 3K-3500 RPM. It sounds like it is coming from behind the dash on the passenger side of the car. I have it on video, but can't post it here. It sounds like whirring? (not really sure how to describe it). I have brought it to a couple dealers who hear the issue but can't tell me what it is. One of them wants $1900 to pull the dash to diagnose the issue. The dash has already been out twice for heater cores, so I'd like to avoid this. Does this sound familiar to anybody?
Thanks!
Danny
Bicyclemaster400 is offline   Reply With Quote
Old 10-17-2017, 04:59 PM   #2
Bicyclemaster400
Actually was able to post it to youtube. Here is the noise:
https://youtu.be/NCCjG0hYGgg
Danny
Old 10-17-2017, 08:22 PM   #3
gringo
gringo's Avatar
Drives: Camaro V6
Sounds like an engine accelerating while going through the gears and some road noise. Normal sounds when driving a car to me.
gringo is offline   Reply With Quote
Old 10-17-2017, 09:47 PM   #4
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
I don't hear anything but engine noise
Talladega is offline   Reply With Quote
Old 10-17-2017, 11:04 PM   #5
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
Its a metallic rattling or sizzle over the top of the engine noise.
Jazzzed is offline   Reply With Quote
Old 10-17-2017, 11:40 PM   #6
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I heard it...turn up the volume fellas im on my laptop. It sounds kind of like a heat shield thats just barley loose.....see if you can crawl under with a rubber hammer and give your exhaust an other stuff a tap.
rontammy0 is offline   Reply With Quote
Old 10-18-2017, 05:15 AM   #7
chuckie669
chuckie669's Avatar
Drives: 2011 ss
I hear it too. Kind of reminds me of when the bolt for my transmission vent tube (metal piece right by exhaust) disappeared and it would tap the exhaust. Was a horrid littler bugger.
Think I recall you can check it from under the passenger side mid car. Little metal tube just up against a rubber vent hose off trans. It then bends around by exhaust with a single bolt holding in place.
chuckie669 is offline   Reply With Quote
Old 10-18-2017, 07:58 AM   #8
steveww
RUSH TWO
steveww's Avatar
Drives: 2014 Camaro 2SS/RS
A 2014 with 2 heater core issues?, any idea what caused it.
I knew the earlier models had some heatercore issues was hoping that issue was fixed.
Window tint, Clear bra, 1 7/8 Headers with Hi-flow cats, ADM Performance-CAI, Slotted/Drilled Rotors with Ceramic carbon fiber pads. Painted Calipers, Drag wheels, Outlaw Catback Quad tips, CFD Shifter with Leather boot upgrade, LSA Supercharger, AEM AFR Gauge
steveww is offline   Reply With Quote
Old 10-18-2017, 09:52 AM   #9
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
Originally Posted by MariaHarmon View Post
well maybe you need to go to the servoce center?
he took it in and they couldn't find anything wrong.
typical, right?
DvKillar is offline   Reply With Quote
Old 10-18-2017, 10:11 AM   #10
Bicyclemaster400
Hey guys,
Good thoughts. Will check the fire wall area and the transmission vent tube tonight.
The heater core went bad 6 months after I bought it and the dealer I bought it from messed up a bunch of other things while the dash was out, so it had to come out again. Just a faulty part, but a huge pain...
Old 09-17-2022, 11:53 PM   #11
Tony Tapia
Drives: 2015 Camaro
https://ls1tech.com/forums/chevrolet...-2-3k-rpm.html
Tony Tapia is offline   Reply With Quote
Old 09-18-2022, 12:21 AM   #12
MjrStfy
MjrStfy's Avatar
Drives: 2015 Chevy Camaro V6 2LT RS
Wondering since you had the heater core replace that it could be this
https://www.camaro5.com/forums/showthread.php?t=405734
MjrStfy is offline   Reply With Quote
Old 09-20-2022, 08:44 AM   #13
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
Mine makes a hissing sound, similar but not identical to yours (and mine is louder and more pronounced). I was told that it's probably just the fluid passing through the heater core. Only happens when I punch it.
ElderJ is offline   Reply With Quote
Old 09-22-2022, 09:15 AM   #14
Jazzzed
Jazzzed's Avatar
This is an old thread. In my case, the noise ended up being the airconditioner compressor pully. It makes a metallic hissing type noise from the bearings or something, but its intermittent. Varying the RPM of the engine will make it go away. It seems to resonate around that 3500rpm area. This may or may not be what you guys are hearing, but that is what it was for me.
Incidentally, it was just a noise. My airconditioner has always worked fine.
Oh yeah, and I just remembered how I figured that out. When the noise is occurring, turn the airconditioning on. This engages that pully, and the noise goes away.
